    NTC temperature sensor
    sensorslopyadctemperaturentc
    26 Posts 6 Posters 15.2k Views 6 Watching
      tobru
      Line 32 should not be indented
      Ouch. This of course should not have happened! Thanks a lot to @robert-hh for spoting this! Looks much better now... But: It seems that the measurement is not really accurate, connecting the 10k resistor instead of the NTC thermistor should give me a value around this (I know that it won't be 100% perfect), but it looks like this:
      sample 0: 1827
      sample 1: 1869
      sample 2: 1823
      sample 3: 1843
      sample 4: 1845
      average sample: 1841
      resistance: 8170
      the code:
      THERMISTORPIN = 'P16'
      NUMSAMPLES = 5
      SERIESRESISTOR = 10000
      adc = machine.ADC(0)
      adcread = adc.channel(attn=3, pin=THERMISTORPIN)
      samples = [0.0]*NUMSAMPLES
      for i in range(NUMSAMPLES):
          samples[i] = adcread()
          print("sample %u: %u" %(i, samples[i]))
          time.sleep(1)
      average = 0
          average += samples[i]
      average /= NUMSAMPLES
      print("average sample: %u" %average)
      resistance = SERIESRESISTOR / ((4095 / average) - 1)
      print("resistance: %u" %resistance)
      Could it be that the ADC isn't very accurate? What can I do to get a more accurate result of the measurement? Or could it be that the equation for calculating the resistance is wrong?
      S J 2 Replies Last reply Reply Quote 0
        slavik73 @tobru
        @tobru I think the problem could be also caused by non-exactly-accurate assumption about an ADC range. Even if we assume it's a 3.2V, it's still not the same as the one you are giving to thermister. I think it could cause some non-linear behavior. (In arduino I think they are using external Vref in this mode.)
          jmarcelino @tobru
          @tobru
          There is some known non-linearity in the ESP32 ADC which is not (yet) being compensated on the ESP-IDF (and thus neither in micropython)
          https://twitter.com/ba0sh1/status/815759185816129536/
          For example up to 0.1v it registers 0.0. So at the least you need to account for that.
          You may be able to compensate these in software. Personally I'd just use a much more accurate dedicated external ADC - connected over I2C for example - for NTC measurements. For example a ADS1115 breakout can be had for less than $2.
            robert-hh
            I'm still thinking how you have connected the thermistor a) between Vcc and ADC (like sketched below) or b) between ADC and GND. From your code, it looḱs like b)
            And yes, there were quite a few notes about the ADC's poor performance. If you need more precise values, you should compensate at least for the actual range.
              tobru @robert-hh
              @robert-hh said in NTC temperature sensor:
              It's currently connected like this:
              3V3
              |-| 10k resistor (instead of NTC)
               +--------------+ P16
              |-| 10k resistor
              GND
              Do you think the code doesn't fit this scheme?
              @jmarcelino said in NTC temperature sensor:
              I've ordered a Velleman MM112 external ADC with I2C interface, I can then compare the values.
                robert-hh
                I think it should. If you NTC is connected between Vcc and ADC, this line:
                should be:
                resistance = SERIESRESISTOR * ((4095 / average) - 1)
                For instance:
                at 50°C, the value of the NTC is 3588 Ohm. That should give an ADC reading of:
                4095 * (10000/(3588 + 10000)) = 3014
                Put that into your formula, and you get 27881 Ohm
                Put that into the other formula, and you get 3587 Ohm.
                Regards, Robert
                  tobru @robert-hh
                  Yes, that looks better, I use the following test code now:
                  NUMSAMPLES = 5
                      time.sleep(1)
                  average = 0
                  Vin = 3.2
                  buffer = average * Vin
                  Vout = buffer / 4095
                  buffer = (Vin / Vout) - 1
                  R2 = 10000 * buffer
                  print("resistance2: %u" %R2)
                  and the output is:
                  sample 0: 1850
                  sample 1: 1836
                  sample 2: 1837
                  sample 3: 1845
                  sample 4: 1829
                  average sample: 1839
                  resistance: 12262
                  resistance2: 12262
                  Nevertheless, the ADC accuracy seems to be very bad so measuring the temperature this way seems useless. I'll try it with an external ADC as soon as it arrived.
                    robert-hh
                    I think you could stil use the built-in ADC, if you requirement for precision is not extreme (like with 1% error). But you have to compensate the errors of the ADC.
                    a) the zero point. look at which input voltage the output is different to zero. According to a comment below, this is somewhat like 0.1 V
                    b) the scaling: Look at which input voltage the output just reaches the maximum value.
                    c) nonlinearity. You could make a compensation table, or ignore it, if it is small enough and outside the range of interest.
                    d) Noise
                    a) and b) is easily compensated for. d) is reduced with taking an average of many samples, like you did. You do not have to wait a second between the samples. A few ms is sufficient, if at all, and a small capacitor like 10 nF with short leads directly at the ADC helps.
                    Another observation: You connect the NTC to 3.2 V (are you sure it's not 3.3V?). The ADC max range is at 3.6 V, the reading at 3.2 V would be 3631. Instead of 4095, you should therefore use 3631 as the virtual maximum value. Then, the resistor value is 9793 (10412 for 3.3 V), which is 2% off the nominal value, and depending of the precision class of the resistor that could be the real value.
                      tobru @robert-hh
                      There is no exterme precision requirement. 1% would be completely fine.
                      d) Noise
                      a) and b) is easily compensated for. d) is reduced with taking an average of many samples, like you did. You do not have to wait a second in between, and a small capacitor like 10 nF with short leads directly at the ADC helps.
                      Thanks for the inputs!
                      It is connected to 3V3, so it is of course 3.3V. I've chosen 3.2V for Vin in the second equation because of the parameter attn=3. I've read that in this threads: https://forum.pycom.io/topic/226/lopy-adcs and here https://forum.pycom.io/topic/602/ntc-temperature-sensor/6
                      Interesting. I must have missed this information in the documentation, I thought 3.3V is the maximum.
                        robert-hh
                        As always, the information given by espressif is poor. Nothing compared to the manuals issued for instance by Atmel, STM or Freescale. It is unclear, how much the attenuation level really is, some say 11db, some say 12 db. 11db would be a factor 3.55, 12 db a factor 3,98 (10**(atten/20)) of the base range, which is ?. In any case, better give it a try. If you have a voltage meter, get the value at the input and scale it by:
                        Vrange = Vinput * (4095/reading)
                          robert-hh
                          So I gave it a try, connected a power source to the input and read the average of 100 samples each. The results are not convincing.
                          a) Even at an average of 100 samples, there is a lot of noise..
                          b) it looks pretty nonlinear., at least at attn 3
                          results:
                          attn = 3
                          value 0 until 125 mV
                          107	mV -> 0
                          200	mV -> 95
                          300	mV -> 215
                          500	mV -> 455
                          700	mV -> 700
                          1000 mV -> 1070
                          1500 mV -> 1700
                          1600 mV -> 1815
                          2000 mV -> 2310
                          2500 mV -> 2930
                          2900 mV -> 3540
                          3000 mV -> 3740
                          3100 mV -> 3955
                          3170 mV -> 4095
                          attn = 0
                          Value 0 until 57 mV
                          100 mV -> 127
                          200 mV -> 550
                          300 mV -> 974
                          500 mV -> 1820
                          700 mV -> 2650
                          900 mV -> 3510
                          1000 mV -> 3933
                          1044 mV -> 4095
                          If you look at that in a graph, at attn 3 the bends up beyond 2.5 V, while the attn=0 graph looks more linear, besides the 0-Offset.
                          That's worse than I expected. The best one can get is to work with attn = 0 and use an external voltage divider.
                          Edit: I found a link that shows an experience, which pretty much matches mine:
                          http://www.esp32.com/viewtopic.php?t=1045
                          The Figures I got are pretty much the same. So 6db attn would be an option too.
                            jmarcelino @robert-hh
                            this is an open issue on ESP-IDF and also the Arduino core
                            https://github.com/espressif/esp-idf/issues/164
                            https://github.com/espressif/arduino-esp32/issues/92
                            The official response from Espressif is:
                            The ADC frontend indeed has a non-linear response. Once characterization data is ready, we will take it into account inside ADC APIs, and update the datasheet with correct values of INL/DNL and effective resolution.
                            So any efforts to compensate it at this stage will likely be rendered useless in a future update once the characterisation is complete (at least at ESP-IDF/MicroPython level)
                            That's also why I suggested an external ADC for the time being, at least that won't change.
                              robert-hh
                              @jmarcelino: Yes, Ive read that. But you would still have to compensate for the non-zero range (at least in your circuit). So at the moment and with limited requirements for precision, using the lower attenuation variants 0 and 6db and simply adding an offset would be sufficient as compensation.
                              If you need precise values, yes, then an external ADC is anyhow recommended.
                              B.T.W. Is there still the option to use the ADC in 10 bit mode, like by an option res = xx in the channel set-up?
                              • 2 / 2
