    LoRa Rx window timing debugging
    fipyloralorawanotaa
    1 Posts 1 Posters 49 Views 1 Watching
      Serafi Nebot 0
      Objective
      Reliably join a LoRaWAN network though OTAA & send/receive data.
      Setup
      The following setup, except the end device, works for a few hundred other devices which have been working for months. None of the already working end devices are Pycom products.
      End device
      FiPy with the following version:
      (sysname='FiPy', nodename='FiPy', release='1.20.2.r6', version='v1.11-c5a0a97 on 2021-10-28', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.7.1')
      Gateway
      MikroTik LoRa gateway configured as a packet forwarder.
      The gateway LoRa channels are the following:
      Number Frequency (MHz) Bandwidth
      0 868.1 125 kHz
      1 868.3 125kHz
      2 868.5 125kHz
      3 867.1 125kHz
      4 867.3 125kHz
      5 867.5 125kHz
      6 867.7 125kHz
      7 867.9 125kHz
      8 868.3 250kHz
      9 868.8 125kHz
      LoRa Server
      Debian machine with the whole ChirpStack server stack:
      • ChirpStack Gateway Bridge
      • ChirpStack Network Server
      • ChirpStack Application Server
      Note: ChirpStack is configured with the default configuration files used in this guide.
      End device code
      import binascii
      from network import LoRa
      if __name__ == "__main__":
          pycom.heartbeat(False)
          pycom.rgbled(0x7f0000)
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868, device_class=LoRa.CLASS_A, public=1, adr=0, tx_retries=0)
          for i in range(0, 16):
              lora.remove_channel(i)
          lora.add_channel(index=0, frequency=868100000, dr_min=0, dr_max=5)
          lora.add_channel(index=1, frequency=868300000, dr_min=0, dr_max=5)
          lora.add_channel(index=2, frequency=868500000, dr_min=0, dr_max=5)
          lora.add_channel(index=3, frequency=867100000, dr_min=0, dr_max=5)
          lora.add_channel(index=4, frequency=867300000, dr_min=0, dr_max=5)
          lora.add_channel(index=5, frequency=867500000, dr_min=0, dr_max=5)
          lora.add_channel(index=6, frequency=867700000, dr_min=0, dr_max=5)
          lora.add_channel(index=7, frequency=867900000, dr_min=0, dr_max=5)
          lora.add_channel(index=8, frequency=868300000, dr_min=0, dr_max=5)
          lora.add_channel(index=9, frequency=868800000, dr_min=0, dr_max=5)
          dev_eui = binascii.unhexlify('0000000000000000')
          app_eui = binascii.unhexlify('0000000000000000')
          app_key = binascii.unhexlify('00000000000000000000000000000000')
          lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=0)
          def rxcb(arg):
              print("RX callback received: {}".format(arg))
          lora.callback(LoRa.RX_PACKET_EVENT, rxcb)
          while not lora.has_joined():
              pycom.rgbled(0x7f7f00)
              time.sleep(5)
              print("joining...")
          print("joined")
          pycom.rgbled(0x007f00)
          # create a LoRa socket
          sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
          # set the LoRaWAN data rate
          sock.setsockopt(socket.SOL_LORA, socket.SO_DR, 5)
          # make the socket blocking
          sock.setblocking(True)
          # send some data
          sock.send(bytes([0x01, 0x02, 0x03]))
          sock.setblocking(False)
          data = sock.recv(64)
          print(data)
      Problem
      Observed behaviour
      Some JoinRequest messages appear to get "lost" as they do not appear in the gateway traffic log. To my understanding the FiPy sends a new JoinRequest message every ~10 seconds.
      It a significant amount of JoinAccept messages to successfully join the network and, once joined, very rarely receives a scheduled downlink message. All JoinRequest messages received by the gateway are successfully sent to & authenticated by the LoRa server, the JoinAccept response however, does not reach the end device.
      Advancements
      Some forum threads have mentioned that similar issues may be related to an incompatibility with the gateway's channels. Therefore, the FiPy's code has been modified to remove the default channel configuration and replace it with the gateway's. This has resulted in a significant improvement with the JoinRequest messages being lost.
      Hypothesis
      Since downlinks only appear to work every few hundred attempts there might be a problem with the Rx window timing.
      I would expect this to be thouroughly tested in the LoRa firmware as the issue would be present on all Pycom devices.
      Is there any way to debug this issue?
      Any other hypothesis/solutions are welcome.
      Thank you
