    Exceptions in micro python
    micropythonexceptions
    12 Posts 4 Posters 2.0k Views 5 Watching
      robert-hh @Eric73
      @eric73 just tried thst on windows MP. If you open a file beforehand, you can use that file handle as second argument to sys.print_exception.
      • K Offline
        kjm
        not on the gpy you can't!
          robert-hh @kjm
          @kjm I'll have to check that tonight. I have no device here at the moment.
          • K Offline
            kjm
            Anybody out there manage to store traceback line numbers to a file on the gpy?
              robert-hh @kjm
              @kjm You could do as follows:
              try:
                  1/0
              except Exception as e:
                  import sys
                  with open("error.log", "a") as f:
                      sys.print_exception(e, f)
              This works for me,
              Pycom MicroPython 1.20.0.rc6 [8d824a0-dirty] on 2019-01-28; FiPy with ESP32
              • K Offline
                kjm
                Ah, perfect! Tanks muchly.
                • K Offline
                  kjm
                  Hey Robert I need to filter out the double inverted commas before I store in the error.log file I tried
                  err=sys.print_exception(e)
                  err=err.replace('"',"")
                  but I got AttributeError: 'NoneType' object has no attribute 'replace'
                    robert-hh @kjm
                    @kjm follow these steps. I just executed at the prompt:
                    >>> from uio import StringIO
                    >>> import sys
                    >>> s = StringIO()
                    >>> try:
                    ...     1/0
                    ... except Exception as e:
                    ...     sys.print_exception(e, s)
                    >>> x=s.getvalue()
                    >>> x
                    'Traceback (most recent call last):\n  File "<stdin>", line 2, in <module>\nZeroDivisionError: divis
                    ion by zero\n'
                    • K Offline
                      kjm
                      Thnx again Robert, for anyone else with a similar requirement I ended up with....
                        import sys; from uio import StringIO
                        s=StringIO(); sys.print_exception(e, s)
                        s=s.getvalue(); s=s.split('\n')
                        line=s[1].split(','); line=line[1]; error=s[2]; err=error+line; print(err)
                        with open ('error.log', 'a') as f: f.write(err)
                        ronald gevern Banned @kjm
