    Pymakr 1.1.13 does not work with VSCode 1.60.0
    Scheduled Pinned Locked Moved Software Tools
    24 Posts 11 Posters 224 Views 11 Watching
      sdfg sdfg
      edit: I got around the last problem below by editting the Pymakr > Global Settings file and removing one of the manufacturer strings (my fypi extension board happens to have Microsoft as Manufacturer string).
      Victory! It took a bunch of hours, but it's fun now that I can start coding :P
        Razvan Grigore
        Same problem here, macbook pro:
        Version: 1.60.2
        Commit: 7f6ab5485bbc008386c4386d08766667e155244e
        Date: 2021-09-22T11:59:27.195Z (1 wk ago)
        Electron: 13.1.8
        Chrome: 91.0.4472.164
        Node.js: 14.16.0
        V8: 9.1.269.39-electron.0
        OS: Darwin x64 19.6.0
        Tried both 1.1.12 and 1.1.13 versions of the plugin, no luck, it does not appear in terminal and when trying to run console commands it says: command 'pymakr.connect' not found
        Thank you!
          somervda
          I think I have run into this the last few releases on VSCode and Pymakr. I have finally bitten the bullet and have turned off automatic updates in VSCode so I can hold them at the versions you called out. I'm not sure why VSCode and Pymakr keep having this problems on new releases, however I love how well they work when they do work, and didn't need to pay for either so can't complain :)
          • Jakob RosenbergJ Offline
            Jakob Rosenberg
            Hi everyone. We've released v1.1.14, which should fix all issues directly related to v1.1.13.
            For questions and feedback regarding v.1.1.14, please see the thread below.
            PyMakr v.1.1.14 thread.
              Meric NESSANGE
              Same Issue here : "command not found" in VSCode
              I use pymakr v2.22.4 and VSCode 1.70.0
              Any workaround to share ?
              Thanks.
                robert-hh @Meric NESSANGE
                @Meric-NESSANGE Roll back VSCode.
                  Meric NESSANGE @robert-hh
                  Hi @robert-hh.
                  till 1.1.12 ?
                    @Meric-NESSANGE If it ever worked, roll back to these versions. If you never used it, my personal opinion would be to stay away from it. According to the complaints in the forum, Pymakr has problems with almost every update of VSCode.
                    G M 2 Replies Last reply Reply Quote 0
                      g0hww @robert-hh
                      @robert-hh It seems to be permanently broken with Atom, which was when I last checked, apparently considered to be abandoned. Everything is falling apart around here.
                        Thanks for answer.
                        Yes, it barrely worked, but I update VSCode in order to solve some connexion issues.
                        Noob error : I don't notice my previous version of VSCode.
                        ok, rolled back to a supposed functionnal version :
                        šŸ¤¦ā€ā™‚ļø
                        ok, let's do it without the preview module :
                        šŸ¤¦ā€ā™‚ļø
                        @g0hww It seems to be permanently broken with Atom
                        šŸ¤¦ā€ā™‚ļø It was my B-plan.
                        Anybody for a C-plan to be able to flash a board ?
                        Same sensation.
                        And it's worrying.
                        Really.
                          @Meric-NESSANGE To upload the firmware you can always use the Pycom updater tool. And to upload code to the device you can use:
                          • ftp (by WiFi)
                          • mpremote by USB
                          As terminal emulator you can use putty (windows), screen (mac), screen or picocom (Linux)
                          As IDE you can as well try Thonny.
                            Hi @robert-hh,
                            OK, I'd some unsuccesful try.
                            Please, can you crosscheck my parameters :
                            • ftp (by WiFi)
                              • connect the PC to the micro wifi
                                • ssid : sipy-wlan-xxxx
                                • pw : www.pycom.io
                              • host name : 192.168.4.1
                              • port : 23
                              • user : micro
                              • pw : python
                              • protocol : FTP (w/o encryption)
                            • mpremote
                              • succesfully installed with pip
                              • got a "no device found" in the cmd panel. Seems not recognized as an application. Any idea ?
                            Thanks.
                              @Meric-NESSANGE Ftp must be unencrypted and limited to 1 connection.
                              for mpremote you have to specify e.g. /dev/ttyUSB0 as interface. Shortcut is u0. E.g.
                              mpremote connect /dev/ttyUSB0 ls
                              or
                              mpremote u0 ls
                              For a windows machine, you have to specifiy the com port.
                              mpremote connect com3 ls
                              See also mpremote --help.
                                connected !!!
                                --help was the enabler ^^
                                Thanks.
                                Unfortunately, not any ">>>" in the prompt. So no way to do anything...
                                M robert-hhR 2 Replies Last reply Reply Quote 0
                                  Meric NESSANGE @Meric NESSANGE
                                  EDIT : OK, wiring issue !
                                  I'M CONNECTED ON A MICROPYTHON ^^
                                    @Meric-NESSANGE looks like the wrong com port.
                                      jchernandez @Meric NESSANGE
                                      @Meric-NESSANGE Hello, how can I upload files to a pycom board through mpremote? My atom and pymakr updated automatically and now no working anymore :/
                                        robert-hh @jchernandez
                                        @jchernandez mpremote has a --help option. For copying files, you have to use the cp subcommand. So as example for copying a file to the board:
                                        mpremote connect /dev/ttyUSB0 cp myfile.py :myfile.py
                                        or just
                                        for using : as a shortcut for the baord's local directory and . for the PC's one. Copying back similar as:
                                        mpremote connect /dev/ttyUSB0 cp :myfile.py myfile.py
                                        or
                                        mpremote connect /dev/ttyUSB0 cp :myfile.py .
                                        The device names at Windows are similar COM3, COM4, .... Shortcuts are:
                                        u0 for connect /dev/tty/USB0
                                        Unfortunately the mount command of mpremote does not work with the PyCom version of MicroPython. That version is too old.
                                        To run a local script without copying it to the board use the run command. If you do not enter a command after the connect, mpremote opens a REPL session.
                                        And before I forget it: With Pycom devices and WiFi active you can always use FTP for copying files. A good FTP client is FileZilla. But some file managers allow using FTP paths as well. User name is micro, password is python.
                                        J B 2 Replies Last reply Reply Quote 1
                                          jchernandez @robert-hh
                                            Bernice McCarthy Banned @robert-hh
                                            @robert-hh said in Pymakr 1.1.13 does not work with VSCode 1.60.0:
                                            or just
                                            or
                                            To run a local script without copying it to the board use the run command. If you do not enter a command after the connect, mpremote opens a REPL session cat mario
                                            you can review the .py file, i think it has that problem
                                            With your input, this post could be even better šŸ’—
