    Pymakr 1.1.13 does not work with VSCode 1.60.0
    Scheduled Pinned Locked Moved Software Tools
    24 Posts 11 Posters 662 Views 11 Watching
      Meric NESSANGE
      Same Issue here : "command not found" in VSCode
      I use pymakr v2.22.4 and VSCode 1.70.0
      Any workaround to share ?
      Thanks.
        robert-hh @Meric NESSANGE
        @Meric-NESSANGE Roll back VSCode.
          Meric NESSANGE @robert-hh
          Hi @robert-hh.
          till 1.1.12 ?
            @Meric-NESSANGE If it ever worked, roll back to these versions. If you never used it, my personal opinion would be to stay away from it. According to the complaints in the forum, Pymakr has problems with almost every update of VSCode.
            G M 2 Replies Last reply Reply Quote 0
              g0hww @robert-hh
              @robert-hh It seems to be permanently broken with Atom, which was when I last checked, apparently considered to be abandoned. Everything is falling apart around here.
                Thanks for answer.
                Yes, it barrely worked, but I update VSCode in order to solve some connexion issues.
                Noob error : I don't notice my previous version of VSCode.
                ok, rolled back to a supposed functionnal version :
                šŸ¤¦ā€ā™‚ļø
                ok, let's do it without the preview module :
                šŸ¤¦ā€ā™‚ļø
                @g0hww It seems to be permanently broken with Atom
                šŸ¤¦ā€ā™‚ļø It was my B-plan.
                Anybody for a C-plan to be able to flash a board ?
                Same sensation.
                And it's worrying.
                Really.
                  @Meric-NESSANGE To upload the firmware you can always use the Pycom updater tool. And to upload code to the device you can use:
                  • ftp (by WiFi)
                  • mpremote by USB
                  As terminal emulator you can use putty (windows), screen (mac), screen or picocom (Linux)
                  As IDE you can as well try Thonny.
                    Hi @robert-hh,
                    OK, I'd some unsuccesful try.
                    Please, can you crosscheck my parameters :
                    • ftp (by WiFi)
                      • connect the PC to the micro wifi
                        • ssid : sipy-wlan-xxxx
                        • pw : www.pycom.io
                      • host name : 192.168.4.1
                      • port : 23
                      • user : micro
                      • pw : python
                      • protocol : FTP (w/o encryption)
                    • mpremote
                      • succesfully installed with pip
                      • got a "no device found" in the cmd panel. Seems not recognized as an application. Any idea ?
                    Thanks.
                      @Meric-NESSANGE Ftp must be unencrypted and limited to 1 connection.
                      for mpremote you have to specify e.g. /dev/ttyUSB0 as interface. Shortcut is u0. E.g.
                      mpremote connect /dev/ttyUSB0 ls
                      or
                      mpremote u0 ls
                      For a windows machine, you have to specifiy the com port.
                      mpremote connect com3 ls
                      See also mpremote --help.
                        connected !!!
                        --help was the enabler ^^
                        Thanks.
                        Unfortunately, not any ">>>" in the prompt. So no way to do anything...
                        M robert-hhR 2 Replies Last reply Reply Quote 0
                          Meric NESSANGE @Meric NESSANGE
                          EDIT : OK, wiring issue !
                          I'M CONNECTED ON A MICROPYTHON ^^
                            @Meric-NESSANGE looks like the wrong com port.
                              jchernandez @Meric NESSANGE
                              @Meric-NESSANGE Hello, how can I upload files to a pycom board through mpremote? My atom and pymakr updated automatically and now no working anymore :/
                                robert-hh @jchernandez
                                @jchernandez mpremote has a --help option. For copying files, you have to use the cp subcommand. So as example for copying a file to the board:
                                mpremote connect /dev/ttyUSB0 cp myfile.py :myfile.py
                                or just
                                for using : as a shortcut for the baord's local directory and . for the PC's one. Copying back similar as:
                                mpremote connect /dev/ttyUSB0 cp :myfile.py myfile.py
                                or
                                mpremote connect /dev/ttyUSB0 cp :myfile.py .
                                The device names at Windows are similar COM3, COM4, .... Shortcuts are:
                                u0 for connect /dev/tty/USB0
                                Unfortunately the mount command of mpremote does not work with the PyCom version of MicroPython. That version is too old.
                                To run a local script without copying it to the board use the run command. If you do not enter a command after the connect, mpremote opens a REPL session.
                                And before I forget it: With Pycom devices and WiFi active you can always use FTP for copying files. A good FTP client is FileZilla. But some file managers allow using FTP paths as well. User name is micro, password is python.
                                J B 2 Replies Last reply Reply Quote 1
                                  jchernandez @robert-hh
                                    Bernice McCarthy Banned @robert-hh
                                    @robert-hh said in Pymakr 1.1.13 does not work with VSCode 1.60.0:
                                    or just
                                    or
                                    To run a local script without copying it to the board use the run command. If you do not enter a command after the connect, mpremote opens a REPL session cat mario
                                    you can review the .py file, i think it has that problem
                                    With your input, this post could be even better šŸ’—
