I Fixed Mine
Hi Guys,
I fixed my miner, but only with the help of this article...
https://zolder.io/hacking-my-helium-crypto-miner/
The author had his apart, found the console/SSH login credentials (user: ubuntu, password: ubuntu) and then dissected the Linux installation.
Here's what was the matter with mine, when Docker tried to start it moaned about...
3 matches found based on name: network ubuntu_default is ambiguous
You can view the Docker networks using this command...
docker network ls
Sure enough it showed multiple entries for the 'ubuntu_default' network...
root@pycom-miner:/home/ubuntu# docker network ls NETWORK ID NAME DRIVER SCOPE 8aec6b6f5e90 bridge bridge local 188661078b8f host host local 9afa4799c04c none null local 40522c0fa720 ubuntu_default bridge local b42ea5ebc1ad ubuntu_default bridge local ca1d3391bf71 ubuntu_default bridge local
I removed all but one of those 'ubuntu_default' networks using...
docker network rm <NETWORK ID>
So I did...
root@pycom-miner:/home/ubuntu# docker network rm b42ea5ebc1ad b42ea5ebc1ad root@pycom-miner:/home/ubuntu# docker network rm ca1d3391bf71 ca1d3391bf71
This seemed to tidy things up a bit and allowed to the update to run. It took my miner from 1.0.5 to 1.0.7.
It's now doing OK. My local LoRaWAN devices are now connecting to this hotspot and I'm expecting the Helium Explorer to start reporting activity again soon.
Pro Tip: I was struggling to get the USB-C console to work with a USB-A to USB-C cable. Once I switched to using a USB-C port on my laptop with a USB-C to USB-C cable (at 115,200 baud for the serial terminal in PuTTY), I got a reliable connection and was able to watch the device boot. I was also able to sign-in using ubuntu/ubuntu.
Pro Tip - Auto Updating: The miner will check for updates from Pycom every 5 minutes but not until the miner has been on for 30 minutes. You can see details of the updating mechanism in the article mentioned above.
Anyway, I hope that helps. I took mine apart to do all this but, as long as you can reach it via SSH, you can login remotely and fix the installation from there.
@DC
That's great. I'm glad my tip helped and that you got it working and updating.
@Jason-Timmins
I logged in and found the same - three ubuntu_default bridges. I deleted two of them then issued a reboot. I then onboarded the hotspot, but didn't assert its location yet. We'll see if this works. Great sleuthing!Now that I can log in via ssh, I can properly halt them or reboot them without pulling the plug. YAY!
UPDATE: It works now and has updated to the version with the web interface.
@DC
It won't update until it's provisioned (I assume that means 'part of the blockchain'), there's a bit of code in the update script that blocks that...if [ ! -f /etc/provisioning.txt ]; then exit 0 fi
That's saying... if there's no provisioning file, exit the update script immediately, so no updates happen until it's provisioned.
@Jason-Timmins
Very nice! Thanks for the info. I will check on the one that has constant disk activity to see if that's the issue. It hasn't updated to the version with the web dashboard even though it is hooked up to WiFi and idling on my desk for a week. It is not onboarded yet - I just wanted to have it update before I onboard/assert and install it.
