    DSB1820 Onewire sensor on SiPy
    sipypymakronewireds18b20
    18 Posts 3 Posters 5.4k Views 3 Watching
      bucknall @sk
      @sk is this from your main.py or your tempSensor.py?
      Developer Evangelist - Pycom
        sk @bucknall
        @bucknall im running from my tempsensor.py.
          bucknall @sk
          @sk Ok, when you import the module ds18x20 it should work fine if it's in the same folder as your tempSensor.py.
          If you open your REPL (either in Pymakr or another tool) and type the following commands, what is your output?
          os.listdir('/flash')
          This should show your the file structure of /flash
            sk @bucknall
            @bucknall I did this in my tempsensor.py file:
            from machine import Pin
            #from ds18x20 import DS18X20
            #d=DS18X20(Pin('G17', mode=Pin.OUT))
            #result=d.read_temps()
            #print(result)
            Which gave this output:
            Running TempSensor.py
            MicroPython v1.8.6-422-g516b861 on 2017-02-07; SiPy with ESP32
              bucknall @sk
              @sk I think you need to either wrap the code in a print statement to see an output
              print(os.listdir('/flash'))
              or run it from the REPL to see the output
              >>> import os
                sk @bucknall
                @bucknall
                ['boot.py', 'sys', 'lib', 'cert', 'main.py', 'project.pymakr']
                So How can I add it to lib?
                  bucknall @sk
                  @sk it looks like your ds18x20.py didn't upload to the SiPy. To use the sync function in Pymakr, to copy your code over to your SiPy, you need to first create a project.
                  Once you're got a new project, if you create a folder called 'lib' and place the ds18x20.py into this folder and then press sync, it should put it into the lib folder!
                    sk @bucknall
                    @bucknall
                    Ok so I made a new project called 'TempSensor' and in the same folder of this project I made another folder called 'lib'.
                    Inside lib folder I pasted the ds18x20.py, onewire.py and onewire.diff libraries.
                    Then in the project folder I made boot.py:
                    from machine import UART
                    uart = UART(0, 115200)
                    os.dupterm(uart)
                    and main.py:
                    pycom.rgbled(0x000000) # rblack
                    #print(result)
                    machine.idle()
                    Then I synced and then ran my program and this is the output:
                    Running main.py
                    ['__init__.py', 'sys', 'lib', 'cert', 'TempSensor.py', 'main.py', 'boot.py', 'project.pymakr']
                    As you can see the library is still not there. But if I go
                    print(os.listdir('/flash/lib'))
                    The output says its there:
                    Running main.py
                    ['ds18x20.py']
                    Why doesn't it show the onewire.py/diff?
                      sk
                      @bucknall
                      Ok all libraries seem to be in the right place now. My main.py:
                      #pycom.rgbled(0x000000) # rblack
                      print(result)
                      machine.idle()
                      My output however gives this error:
                      Syncing the project with the SiPy. Please wait...
                      Successfully synced!
                      Running main.py
                        File "<stdin>", line 8, in <module>
                        File "/flash/lib/ds18x20.py", line 47, in __init__
                        File "/flash/lib/onewire.py", line 246, in scan
                        File "/flash/lib/onewire.py", line 274, in _search
                        File "/flash/lib/onewire.py", line 148, in write_byte
                      NameError: name 'pin_lalue' is not defined
                      "pin_lalue" isn't in any of my files or libraries? Why is it looking for something that doesn't exist?
                        sk
                        I've also followed this pycom Onewire DS18X20 tutorial but the output is again looking for something that doesn't exist:
                        Running main.py
                          File "<stdin>", line 9, in <module>
                          File "/flash/lib/onewire.py", line 162, in __init__
                          File "/flash/lib/onewire.py", line 124, in scan
                          File "/flash/lib/onewire.py", line 132, in _search_rom
                          File "/flash/lib/onewire.py", line 36, in reset
                        NameError: name 'enabXe_irq' is not defined
                        at line 36 in the onewire library it is enable_irq(1)... not enabXe_irq. Paymkr is replacing the 'l' with 'X'???
                          livius
                          use official onewire driver
                          https://github.com/pycom/pycom-libraries/tree/master/examples/onewire
                          it work for me on Wipy2.0
                          but first check if your file is not corrupted
                          try compare it in text editor e.g Notepad++, Total Comander, WinMerge ...
                          i mean - read file e.g. throught ftp and compare with file you thing that should be stored
                          because i see in your error message corrupted name "enabXe_irq" which not exists in onewire driver
                            sk @livius
                            @livius
                            0_1487543077630_onewire.py
                            this doesnt have enableXe_irq, I don't think its the files thats faulty. Something is wrong with my code or the order I'm doing things, I'm pretty sure, I just don't know what?
                              livius @sk
                              @sk
                              Is this what you downloaded from board or what you have on the computer?
                              Previously (for me still - however less than before) there are some corruption of files stored on the board.
                              try something like this
                              f = open('onewire.py', 'r+')
                              d = f.readall()
                              print(d)
                              do you see some corruption in content?
                              Try also downloading file throught ftp - is this file same as your on the computer?
