    lopy not running main.py
    lopyboot.pyrepl
    19 Posts 6 Posters 7.1k Views 6 Watching
      mmarkvoort @gouao
      @gouao
      I have checked it with a simple flash to green in the main.py.
      That is working on reset and on power plug.
      In my other program it is only printing to console. So like I said earlier, it seems that it wont show it in pymakr when power plug. But it was a nice confirmation it does boot on power plug!
      I have also had some trouble with pymark and curious about what other options there are.
        gouao @mmarkvoort
        @mmarkvoort
        Well, pymakr is perma failing to establish a connection with the board, I don't know if you had that error too ?
        I can't even see my output e.g. putty screen (issue I explained below) and now pymakr.
          mmarkvoort @gouao
          @gouao
          I can connect through pymakr, but after power plug I have to click in console to reconnect.
          On my windows it also didn't work at first. I had to install a driver for USB serial converter by hand, mine called FTDI. After that i could use it in pymakr.
          Are you able to update the firmare?
            gouao @mmarkvoort
            @mmarkvoort
            i had the same issue, so i flashed the lopy , and it went well. Do you know the procedure ?
            Did you try this on linux ? I had to install FTDI driver too but seems that it isn't enough.. That's why I can't even update de firmware, because of an error : Something failed trying to connect to the device.
            I guess it's because of what I explained bellow on the authorization issues.
              mmarkvoort @gouao
              @gouao
              I didn't try this on linux.
              Here they say there are two types of FTDI drivers. VCP and D2XX. I can't remember which one I used. But the first one I tried said it installed the missing driver, but when I wanted to connect to the LoPy it didn't work. After research I deleted the driver and tried the other. After that I was able to connect to the LoPy.
              It was very confusing because the driver said it was installed correctly.
                gouao @mmarkvoort
                @mmarkvoort
                For now it's ok for me concerning the FTDI drivers, but I agree it's a bit confusing in the first place.
                Now I can connect on it e.g. REPL, I am curious about what other options @livius is talking about, because I actually encounter some connection issues with pymakr.
                  livius @gouao
                  @gouao
                  I use this setup:
                  1. filezilla to modify files and write it back + Notepad++(to nicely edit files)
                  2. Arduino IDE-and from it COM port monitor to see repl and send command back by repl
                    I use Windows OS but it is avaiable on linux also
                    After install you must only set COM number and baud rate - and if you need not only read data by repl but also send commands - change line break termination - and it work like a charm :)
                  G 1 Reply Last reply Reply Quote 1
                    gouao @livius
                    @livius
                    1. For filezilla, are you perma connected on the lopy-wlan or you have some software settings in order to modify and transfer files while the lopy connected in serial, without establish a connection on the wlan ?
                    2. True it works well :)
                      livius @gouao
                      @gouao
                      I have connected filezilla permanently to Wipy and do modifications and send it back.
                      But i do modifications on files on computer and do not use option to edit file on board "directly"
                      I modify on left panel not on the right panel ;-)
                        gouao @livius
                        @livius
                        This is not what I meant, but while you are doing it, are you connected to the "wipy-wlan" network ?
                          livius @gouao
                          @gouao
                          yes i connet to Wipy AP (wipy-wlan)
                          and one hint
                          to simplify developing process and speed it up
                          i put always in the while true loop check if some button is pressed and break this loop
                          this elimiminate need to restart board and reconnect to it :)
                          Of course if you do not need to change from AP to STA mode
                            johnmcdnz
                            I'm having a similar issue now.
                            main.py will run after CTRL-D or machine.reset(). But, power cycling the Lopy (on expansion board) will connect REPL to pymakr, but main does not seem to run.
                            I've done an os flash, and rewritten all the files. Problem continues though.
                            I'm wondering if it is going to safe boot, factory mode as here:
                            https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html#boot-modes-and-safe-boot
                            How can I can tell which mode is used?
                            I've reset the expansion board jumpers and tightened them up as best I can. Could these be the problem?
                            • 李 Offline
                              李鴻志 @gouao
                              @gouao Have you deleted the first line? The first line cannot be deleted.
                              # main.py -- put your code here!
