    ADXL 345 (from Adafruit)
    adxl345accelerometersensoradafruitsensors
    14 Posts 6 Posters 4.3k Views 6 Watching
      Lokefar
      Has anyone already written a library for this sensor? Or are in the proces of doing so?
      Am a bit lost at the moment on how to write the sensor driver.
      The sensor is this one https://www.adafruit.com/products/1231
        livius @Lokefar
        @Lokefar
        look here - should be simple to convert
        https://github.com/pimoroni/adxl345-python/blob/master/adxl345.py
          Lokefar @livius
          @livius Thanks. I will look into that one.
            Lokefar
            Have been trying to write a library for the sensor (Or at least a class that can be turned into a library), but I can't seem to get it to work. This is the code I have written and it is inspired by this https://github.com/pimoroni/adxl345-python/blob/master/adxl345.py
            Any help would be greatly appreciated!
            from machine import I2C
            ADXL345_ADDR = 0x53
            BW_RATE_100HZ = 0x0B
            POWER_CTL = 0x2D
            MEASURE = 0x08
            DATA_FORMAT = 0x31
            AXES_DATA = 0x32
            BW_RATE = 0x2C
            RANGE_2G = 0x00
            SCALE_MULTIPLIER = 0.004
            EARTH_GRAVITY_MS2 = 9.80665
            class ADXL345(object):
            	def __init__(self, i2c=None):
            		self.i2c = i2c
            		self.addr = ADXL345_ADDR
            		print('One')
            		self.setBandwidthRate(BW_RATE_100HZ)
            		self.setRange(RANGE_2G)
            		self.enableMeasurement()
            	def enableMeasurement(self):
            		i2c.writeto(self.addr, bytes(POWER_CTL))
            		i2c.writeto(self.addr, bytes(MEASURE))
            	def setBandwidthRate(self, rate_flag):
            		print('Two')
            		i2c.writeto_mem(self.addr, bytes(BW_RATE)
            	def setRange(self, range_flag):
            		value = i2c.readfrom_mem(self.addr, bytes(DATA_FORMAT))
            		print('here')
            		value &= ~0x0F;
            		value |= range_flag;
            		value |= 0x08;
            		i2c.writeto(self.addr, DATA_FORMAT, value)
            	def getAxes(self, gforce = False):
            		bytes = i2c.readfrom(self.addr, AXES_DATA, 6)
            		x = bytes[0] | (bytes[1] << 8)
            		if(x & (1 << 16 - 1)):
            			x = x - (1<<16)
            		y = bytes[2] | (bytes[3] << 8)
            		if(y & (1 << 16 - 1)):
            			y = y - (1<<16)
            		z = bytes[4] | (bytes[5] << 8 )
            		if(z & (1 << 16 - 1)):
            			z = z - (1<<16)
            		x = x * SCALE_MULTIPLIER
            		y = y * SCALE_MULTIPLIER
            		z = z * SCALE_MULTIPLIER
            		if gforce == False:
            			x = x * EARTH_GRAVITY_MS2
            			y = y * EARTH_GRAVITY_MS2
            			z = z * EARTH_GRAVITY_MS2
            		x = round(x,4)
            		y = round(y,4)
            		z = round(z,4)
            		return {"x": x, "y": y, "z": z}
            print('Start')
            for i in range(0,10):
            	adxl345 = ADXL345()
            	axes = adxl345.getAxes(True)
            	print(axes['x'])
            	sleep_ms(25)
            Also for some reason the LED light on the expansion board has started to blink blue again.
              rikkertmark
              @Lokefar
              I Think the heartbeat is Enabled
              Please put the following code in your main.py or boot.py
              pycom.heartbeat(False)
              I hope this is the solution for your blue light problem
                livius @Lokefar
                @Lokefar
                i do not have this sensor to test but i have fixed some errors:
                ADXL345_ADDR = 0x53
                POWER_CTL = 0x2D
                MEASURE = 0x08
                DATA_FORMAT = 0x31
                AXES_DATA = 0x32
                BW_RATE = 0x2C
                RANGE_2G = 0x00
                		self.i2c = i2c
                		print('One')
                		i2c.writeto(self.addr, bytes([POWER_CTL]))
                		i2c.writeto(self.addr, bytes([MEASURE]))
                		print('Two')
                		i2c.writeto_mem(self.addr, BW_RATE, bytes([rate_flag]))
                		value = i2c.readfrom_mem(self.addr, DATA_FORMAT, bytes([range_flag]))
                		print('here')
                		value &= ~0x0F;
                		value |= 0x08;
                			x = x - (1<<16)
                			y = y - (1<<16)
                			z = z - (1<<16)
                		if gforce == False:
                		x = round(x,4)
                		y = round(y,4)
                		z = round(z,4)
                print('Start')
                	adxl345 = ADXL345()
                	print(axes['x'])
                	sleep_ms(25)
                  bucknall
                  Hey @Lokefar this looks really cool! I'd love to add it to our libraries repository on GitHub!
                  When you finish and wish to share it, feel free to drop a pull request at https://github.com/pycom/pycom-libraries and we'll happily add it to our example library :)
                  Developer Evangelist - Pycom
                    Lokefar @livius
                    @livius Thanks for the fixes. However, I still get an error:
                      File "main.py", line 79, in <module>
                      File "main.py", line 27, in __init__
                      File "main.py", line 39, in setRange
                    TypeError: can't convert bytes to int
                    The problem seems to be with this line:
                    I noticed that you changed BW_RATE to an int instead of a hex. Tried changing DATA_FORMAT to 49 but that didn't solve the issue.
                      Lokefar @bucknall
                      @bucknall Will do :)
                        livius @Lokefar
                        @Lokefar said in ADXL 345 (from Adafruit):
                        i revert this - this was only my try and forgot to revert
                        this line should be:
                        value = i2c.readfrom_mem(self.addr, DATA_FORMAT, range_flag)
                          livius
                          @Lokefar any progress? :)
                            Lokefar @livius
                            @livius Yup I got it working. Just looking into cleaning up the code and add a few things then I will make it available for all to use :)
                              arthurlutz
                              @Lokefar I'm happy to help with clean up and testing your code.
                                Divij Vignesh
                                @Lokefar Can you post the final working code for this sensor with lopy 4?
