    LoPy UART for GPS not reading data
    lopy uart gps
    17 Posts 4 Posters 4.9k Views 4 Watching
      livius @johnmcdnz
      @johnmcdnz
      P3 and P4 are valid
      You can test if UART1 work by changing boot.py from uart 0 to uart 1
      but you must have some TTL USB to UART converter to test if it work - or computer with native COM port.
      If you got repl on it than it should work for you with GPS also.
      I am quite sure that i have tested UART 1 before and it worked with converter.
      But it was with old firmware...
      What firmware version do you have? 1.6.5?
      And one more tip - did you tried connecting gps to uart0 instead of Uart1 without expansion board?
      To see if you can recive something?
        johnmcdnz
        Thanks for the quick reply.
        My test is now working. I can't explain why!
        I changed a few things, like removed the jumper pins, then replaced them.
        Changed the UART0 baudrate to 9600, and then back to 115200.
        None of this is relevant though, as from power up the unit is now receiving fine.
        Odd. I'd like to think I 'fixed' something, but don't believe I changed anything useful.
        Anyway, now I can proceed!
        L affoltepA 2 Replies Last reply Reply Quote 0
          livius @johnmcdnz
          @johnmcdnz
          good to here that it work for you.
          Maybe there was some not linked to contacts.
          • affoltepA Offline
            affoltep @johnmcdnz
            @johnmcdnz I did a post of a minimalistic NMEA parser. see here. Perhaps it might help you as well
            L J 2 Replies Last reply Reply Quote 0
              livius @affoltep
              @affoltep @johnmcdnz
              just curious - what gps module do you use?
              And if you can tell why? :)
              J affoltepA 2 Replies Last reply Reply Quote 0
                johnmcdnz @livius
                @livius It's this
                http://www.addicore.com/NEO-6M-GPS-p/231.htm
                available and cheap :-)
                (I don't buy from that website, just a local supplier of the same thing)
                • affoltepA Offline
                  affoltep @livius
                  @livius This module here, as well cheap and with integrated antenna.
                    livius @johnmcdnz
                    @johnmcdnz
                    thank you - yes it is really good
                    @affoltep
                    interesting - i didn't see it before -
                    is it fast and accurate? Looks really interestingly
                      johnmcdnz @livius
                      @livius Looks like a reasonable unit, claims 2.5m accuracy, <30s fix from cold and 1s from hot start.
                        johnmcdnz @affoltep
                        @affoltep I have copied your code. Excuse my ignorance with Python, what's the correct way to pass the data string to the code and read the response.
                        e.g. if NMEA string is in 'data', and decode is to be in 'place'
                        place = NmeaParser.update(data)
                        I know this is incorrect, but what is right?
                          johnmcdnz @johnmcdnz
                          Is this correct:
                              place = NmeaParser()
                              place.update(data)
                              print (place.longitude,  ":",  place.latitude)
                          affoltepA 1 Reply Last reply Reply Quote -1
                          • affoltepA Offline
                            affoltep @johnmcdnz
                            @johnmcdnz Here are some code fragments how I use:
                            #initialize UART interface to the GNSS module
                            gps_pps = Pin('P23',  mode = Pin.IN)
                            gps_enable = Pin('P8',  mode=Pin.OUT)
                            gps_enable(False)
                            gps_uart = UART(1, 9600)
                            gps_uart.init(9600,  bits=8,  parity=None,  stop=1)
                            #Create NMEA structure
                            nmea = NmeaParser()
                                latitudebinary = 0
                                longitudebinary = 0
                                altitude = 0
                                hdop = 0
                                newpos = False
                             while not newpos:
                                    if gps_uart.any():
                                        nmea.update(gps_uart.readline())
                                    if nmea.fix_stat & nmea.valid_sentence:
                                        newpos = True
                                    if  (time.ticks_diff(start,  time.ticks_ms()) > GNSS_TRIAL):
                                        pycom.rgbled(red)
                                        print('No actual GNSS postition')
                                        time.sleep(0.2)
                                        pycom.rgbled(off)
                                        return
                                latitudebinary = int(((nmea.latitude + 90) / 180) * 16777215)
                                longitudebinary = int(((nmea.longitude + 180) / 360) * 16777215)
                                altitude = int(nmea.altitude)
                                hdop = int(nmea.hdop * 10)
                            Hope it is understandable ;)
                              johnmcdnz @affoltep
                              @affoltep Many thanks for the help. I'll carry on work with it tomorrow. Made good progress tonight. Cheers.
                                I have completed this project and have posted on this topic:
                                https://forum.pycom.io/topic/819/lopy-gps-receiver-project
                                @affoltep
                                  raaden89
                                  hi @affoltep i tried to connect a gps to my lopy4 and use your code, but it's not working.. of course the gps led is blinking and the code is running well.
                                  this is my wired setup
                                  can you help me please?
