    LoPy UART for GPS not reading data
    lopy uart gps
    17 Posts 4 Posters 4.8k Views 4 Watching
      johnmcdnz
      Thanks for the quick reply.
      My test is now working. I can't explain why!
      I changed a few things, like removed the jumper pins, then replaced them.
      Changed the UART0 baudrate to 9600, and then back to 115200.
      None of this is relevant though, as from power up the unit is now receiving fine.
      Odd. I'd like to think I 'fixed' something, but don't believe I changed anything useful.
      Anyway, now I can proceed!
      L affoltepA 2 Replies Last reply Reply Quote 0
        livius @johnmcdnz
        @johnmcdnz
        good to here that it work for you.
        Maybe there was some not linked to contacts.
        • affoltepA Offline
          affoltep @johnmcdnz
          @johnmcdnz I did a post of a minimalistic NMEA parser. see here. Perhaps it might help you as well
          L J 2 Replies Last reply Reply Quote 0
            livius @affoltep
            @affoltep @johnmcdnz
            just curious - what gps module do you use?
            And if you can tell why? :)
            J affoltepA 2 Replies Last reply Reply Quote 0
              johnmcdnz @livius
              @livius It's this
              http://www.addicore.com/NEO-6M-GPS-p/231.htm
              available and cheap :-)
              (I don't buy from that website, just a local supplier of the same thing)
              • affoltepA Offline
                affoltep @livius
                @livius This module here, as well cheap and with integrated antenna.
                  livius @johnmcdnz
                  @johnmcdnz
                  thank you - yes it is really good
                  @affoltep
                  interesting - i didn't see it before -
                  is it fast and accurate? Looks really interestingly
                    johnmcdnz @livius
                    @livius Looks like a reasonable unit, claims 2.5m accuracy, <30s fix from cold and 1s from hot start.
                      johnmcdnz @affoltep
                      @affoltep I have copied your code. Excuse my ignorance with Python, what's the correct way to pass the data string to the code and read the response.
                      e.g. if NMEA string is in 'data', and decode is to be in 'place'
                      place = NmeaParser.update(data)
                      I know this is incorrect, but what is right?
                        johnmcdnz @johnmcdnz
                        Is this correct:
                            place = NmeaParser()
                            place.update(data)
                            print (place.longitude,  ":",  place.latitude)
                        affoltepA 1 Reply Last reply Reply Quote -1
                        • affoltepA Offline
                          affoltep @johnmcdnz
                          @johnmcdnz Here are some code fragments how I use:
                          #initialize UART interface to the GNSS module
                          gps_pps = Pin('P23',  mode = Pin.IN)
                          gps_enable = Pin('P8',  mode=Pin.OUT)
                          gps_enable(False)
                          gps_uart = UART(1, 9600)
                          gps_uart.init(9600,  bits=8,  parity=None,  stop=1)
                          #Create NMEA structure
                          nmea = NmeaParser()
                              latitudebinary = 0
                              longitudebinary = 0
                              altitude = 0
                              hdop = 0
                              newpos = False
                           while not newpos:
                                  if gps_uart.any():
                                      nmea.update(gps_uart.readline())
                                  if nmea.fix_stat & nmea.valid_sentence:
                                      newpos = True
                                  if  (time.ticks_diff(start,  time.ticks_ms()) > GNSS_TRIAL):
                                      pycom.rgbled(red)
                                      print('No actual GNSS postition')
                                      time.sleep(0.2)
                                      pycom.rgbled(off)
                                      return
                              latitudebinary = int(((nmea.latitude + 90) / 180) * 16777215)
                              longitudebinary = int(((nmea.longitude + 180) / 360) * 16777215)
                              altitude = int(nmea.altitude)
                              hdop = int(nmea.hdop * 10)
                          Hope it is understandable ;)
                            johnmcdnz @affoltep
                            @affoltep Many thanks for the help. I'll carry on work with it tomorrow. Made good progress tonight. Cheers.
                              I have completed this project and have posted on this topic:
                              https://forum.pycom.io/topic/819/lopy-gps-receiver-project
                              @affoltep
                                raaden89
                                hi @affoltep i tried to connect a gps to my lopy4 and use your code, but it's not working.. of course the gps led is blinking and the code is running well.
                                this is my wired setup
                                can you help me please?
