    How to solve the firmware update failures
    63 Posts 15 Posters 48.6k Views 16 Watching
      livius @Ralph
      @Ralph
      I have tried it
      It can conect and send data to wipy
      but it can not connect after rebot and say that update failed
      It store image to Wipy because wipy can not start normally only in "self" mode and it revert temporarly to old version.
      After that problems i have tried to put the same appimg.bin self by ftp with same result. It store bin file and of course it dissapear
      but wipy can not start - only in self mode
      • X Offline
        Xykon administrators
        I don't have a WiPy2 but if someone can upload the 4MB flash dump I can take a look to confirm the memory regions for the firmware images. I'd be surprised if they are any different from the LoPy though.
        Christian Ehlers
          Bashir @Xykon
          @Xykon said in How to solve the firmware update failures:
          Don't use the ftp method, if you look at Xykon post below you will have a solution. I tried everything and the only thing the worked was (on a windows OS):-
          1. Install python 2.7 and pyserial
          2. Run the tool to unlock the flash area via command prompt (See official instructions)
          3. Install the standalone update tool (next, next finish)
          4. Copy the appropriate bin file for your device from C:\Program Files (x86)\Pycom\Pycom Firmware update\Upgrader to the location of the tools folder e.g. C:\flash_debug_tool
          5. Open CMD in the directory you have the tools in e.g. "C:\flash_debug_tool" or cd to it and run the below
            esptool.py --chip esp32 --port COM3 --baud 115200 write_flash 0x210000 lopy_0.9.1.b1_868.bin -fs 4MB -z
          Change the com3 to your comport number
          Change the lopy_0.9.1.b1_868.bin to your bin file name (lopy_0.9.1.b1_868.bin, lopy_0.9.1.b1_915.bin or wipy_0.9.1.b1.bin)
          this will install the latest firmware onto the default boot partition.
          thank you
            livius
            i try
            esptool.py --chip esp32 --port COM3 --baud 115200 write_flash 0x210000 wipy_0.9.1.b1.bin -fs 4MB -z
            and got error:
            C:\Python27\flash_debug_tool>esptool.py --chip esp32 --port COM3 --baud 115200 w
            usage: esptool [-h] [--port PORT] [--baud BAUD]
            {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,
            make_image,elf2image,read_mac,chip_id,flash_id,read_flash,verify_flash,erase_fla
            sh,version}
            esptool: error: argument operation: invalid choice: 'esp32' (choose from 'load_r
            am', 'dump_mem', 'read_mem', 'write_mem', 'write_flash', 'run', 'image_info', 'm
            ake_image', 'elf2image', 'read_mac', 'chip_id', 'flash_id', 'read_flash', 'verif
            y_flash', 'erase_flash', 'version')
            • X Offline
              Are you sure you copied the command correctly? Maybe try typing it manually on the command line?
              Christian Ehlers
                livius
                i try type it but the same error
                in previous post you have copy from cmd.exe window - without any modification - maybe i miss something?
                • X Offline
                  What happens when you run "esptool.py version" and "esptool.py --chip esp32". Can you please post exact output of both commands?
                  Christian Ehlers
                    livius
                    I see that i have python 2.7.11
                    with python 2.7.12 now all looks good :)
                    Will be good to see in steeps that we need python 2.7.12
                    esptool.py v2.0-dev
                    Connecting...
                    Uploading stub...
                    Running stub...
                    Stub running...
                    Attaching SPI flash...
                    Configuring flash size...
                    Erasing flash...
                    Unc size 615696 comp size 362758 comp blocks 355
                    Wrote 362758 bytes at 0x00210000 in 32.6 seconds (89.1 kbit/s)...
                    Hash of data verified.
                    Leaving...
                      Ralph
                      Very nice to hear you got it working @livius
                      If anyone still has problems with firmware update failures: 0.9.2.b1 has just been released. This release fixes the bug where the flash memory gets write protected in some cases.
                      • X Offline
                        Xykon administrators @Ralph
                        I just tried the new firmware updater for Windows, it goes through the questions about LoPy/country/COM port but then fails immediately. Trying to figure out why.
                        I manually flashed the firmware, partition table and bootloader so it's not a big problem but I'm curious why the updater doesn't work.
                        Christian Ehlers
                          AgriKinetics
                          @Xykon Hi, we are having the same problem, although after multiple attempts, it did get past that immediate fail, but, then had a fail with an unknown error in pythonW. Not sure what is going at the moment.
                            livius
                            Maybe because it is still wipy_0.9.1.b1.bin not wipy_0.9.2.b1.bin
                            i look into the folder and there is 1 not 2.
                              AgriKinetics
                              The correct 0.9.2.b1 is in the 'firmware' folder. I tried copying into the main 'upgrader' folder, but, the Upgrader still fails. Thought it might be the version of python (I was running 3.5) but, 2.7.12 fails also.
                                Ralph
                                Thanks for pointing this out. It must be an issue with the windows build of the updater, since the mac version works. We'll try to figure it out and get back to you guys as soon as we can.
                                  livius
                                  i do manual update by:
                                  esptool.py --chip esp32 --port COM8 --baud 115200 write_flash 0x210000 wipy_0.9.2.b1.bin -fs 4MB -z
                                  esptool.py --chip esp32 --port COM8 --baud 115200 write_flash 0x204000 partitions.bin -fs 4MB -z
                                  esptool.py --chip esp32 --port COM8 --baud 115200 write_flash 0x201000 bootloader.bin -fs 4MB -z
                                  i can connect by ftp and by telnet
                                  by tenet i got:
                                  os.uname()
                                  (sysname='WiPy', nodename='WiPy', release='0.9.2.b1', version='333b92c on 2016-10-26', machine='WiPy with ESP32')
                                  but when i start wipy2.0 with board2.0
                                  i can not connect by pymark - i do not know why it not "listen" on UART
                                  but i can do above operations again - and as i understand corectly it is done by UART?
                                  • X Offline
                                    Xykon administrators @livius
                                    @livius There are some extra steps in the updater to preserve your flash memory (MAC address, files on /flash). Since you skipped these steps it's likely your boot.py was overwritten.
                                    Upload a new boot.py file with the following code:
                                    from machine import UART
                                    uart = UART(0, 115200)
                                    os.dupterm(uart)
                                    P.S. Does anyone know where to find the formatting guide for this forum? I've seen people post source codes with a nice black background and syntax highlighting. How do you do that? Is there a help button somewhere for this?
                                    Christian Ehlers
                                    • X Offline
                                      os.dupterm(uart)
                                      Christian Ehlers
                                        livius
                                        Thank you for the help but it does not change anything
                                        still pymakr can not connect :(
                                        I see that update script does erase only some block(3.5MB)
                                        i ommit that and i clear block
                                        If someone have mre concept :)
                                          livius
                                          interested that UART work ok
                                          with com port monitor i retrive data without any problem only PYMAKR can not connect
                                          • X Offline
                                            So far I did manage to get the Linux updater to work.
                                            In ./bin/updater I set BAUD_RATE = 115200 and commented #self.esp.change_baud(baudrate)
                                            I tried the same thing in the Windows version but it still doesn't work.
                                            Christian Ehlers
                                            • 3 / 4
