    firmware
    113 Posts 34 Posters 90.2k Views 32 Watching
      constantinos
      Daniel,
      I lost the functionality of receiving messages from RFM95. It was working with firmware version 1.2.2 and now is lost.
      I just receive nothing at all now.
        @constantinos please try playing with the public argument in the constructor:
        https://docs.pycom.io/pycom_esp32/library/network.LoRa.html#network.lora.init
        Before the last 2 releases the default of True for the public sync word was not being honoured, and now it is. Set this value to False and that will most likely make the LoPy work with the RFM95 again.
          constantinos @daniel
          @daniel Thanks! It works!
            rskoniec
            @daniel Really nice update! NanoGateway and OTAA node works like a charm! Thank you Pycom Dev Team! :)
              Thanks for the thumbs up!! :-)
                johncaipa
                Someone can help me with an example of how to use it on US or AU frequencies, I still can not do it on my own. Thanks
                  robert-hh
                  @daniel Hello Daniel, I do not want to impose any kind of pressure on you, since you are doing a great work in imroving the device, but at what time do you plan the next update of the github repository with the micropython files?
                    @robert-hh, no worries, our only focus from today onwards is code maturing and doing the migration to the MicroPython migration. We'll also update our own repo as we were sorting out the way to publish Sigfox libraries.
                      @johncaipa, for sure, I'll work on an example for US frequencies and will add to the same repo where the other are. We'll do our best to get it done today or tomorrow.
                        Colateral
                        If Wipy WLAN is configured simply as STA-AP ... the ftp is not working.
                        from network import WLAN
                        wlan = WLAN(mode=WLAN.STA_AP, ssid='Cola', auth=(WLAN.WPA2, 'abc12345678'))
                        wlan.ifconfig(id=1, config=('192.168.10.1, '255.255.255.0', '192.168.10.1', '192.168.10.1'))
                        connect to 'Cola'
                        and ftp(with micro/python) is connecting on 192.168.10.1 but fails on root dir (/flash)
                          livius @Colateral
                          @Colateral
                          I also wait for this but still do not know how to work with it
                          STA work but AP not able to connect
                          https://forum.pycom.io/post/4202
                            robert-hh
                            @Colateral: I tried your setting and it worked fine for both addresses (STA and AP), using command line ftp on Linux. Did you use passive mode? Active mode is not supported.
                              Colateral @robert-hh
                              @robert-hh Yes. It is passive mode. My environment is on Windows10. I tried with WinScp, TotalCommander and Windows10 ftp in passive mode. I saw that is working if I use the default 192.168.4.1 IP instead of the custom IP 192.168.10.1 .
                                robert-hh
                                @Colateral That sounds strange that 192.168.4.1 works, but not 192.168.10.1. The other thing that suprises me is, that you used command line ftp on WIndows 10 in passive mode. The one I have here does not support it. Do you have a special version?
                                C 2 Replies Last reply Reply Quote 0
                                  gas @jmarcelino
                                  @jmarcelino
                                  doesn't this in lower case
                                  I tried the lorwan nano but no luck i don't see it connected
                                  I changed the WiFi parameters and the use the code snippet to generate the gateway_id (i added .lower())
                                  added the gateway on TTN using the same Id
                                  but no lock i don't see pull/push arriving to TTN
                                  do we need to change the router address too ?
                                    livius @robert-hh
                                    @robert-hh said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
                                    Did you tried WLAN.STA_AP? or separately? WLAN.STA and another try WLAN.AP. Separately it work but not as WLAN.STA_AP.
                                    I have tested this and i can not connect to AP in that mode.
                                    But i have while True: loop.
                                    Inside loop i have machine.idle but this do not help.
                                    I see Wipy on the list of networks but can't connect.
                                      rskoniec @gas
                                      @gas On the TTN gateway configuration you should use router.eu.thethings.network:1700 from config.py @jmarcelino addons generating GATEWAY_ID are OK.
                                        robert-hh
                                        @livius Yes, I used STA_AP mode, and connected without rebooting the LoPy to the STA and AP, one after the other. At the same time it's not possible since only one connection at a time is allowed. But the behaviour was a little bit inconsistent. In active mode, trying the ls command, I got two different error messages, when it should be the same all the time.
                                          Colateral @livius
                                          @livius I tried and STA_AP is working. I am connected with my laptop on AP (ftp getting files) and the WiPy is connected to local server sending data. I replied to your topic ... seems that is missing connect
                                            gas @rskoniec
                                            @rskoniec
                                            Thanks itis exactly what i have
                                            I see push pull but nothing on the TTN
                                            I'm missing something .. not sure where (wifi is connected )
                                            • 5
                                            • 6
                                            • 2 / 6
