    firmware
    113 Posts 34 Posters 90.2k Views 32 Watching
      rskoniec
      @daniel Really nice update! NanoGateway and OTAA node works like a charm! Thank you Pycom Dev Team! :)
        Thanks for the thumbs up!! :-)
          johncaipa
          Someone can help me with an example of how to use it on US or AU frequencies, I still can not do it on my own. Thanks
            robert-hh
            @daniel Hello Daniel, I do not want to impose any kind of pressure on you, since you are doing a great work in imroving the device, but at what time do you plan the next update of the github repository with the micropython files?
              @robert-hh, no worries, our only focus from today onwards is code maturing and doing the migration to the MicroPython migration. We'll also update our own repo as we were sorting out the way to publish Sigfox libraries.
                @johncaipa, for sure, I'll work on an example for US frequencies and will add to the same repo where the other are. We'll do our best to get it done today or tomorrow.
                  Colateral
                  If Wipy WLAN is configured simply as STA-AP ... the ftp is not working.
                  from network import WLAN
                  wlan = WLAN(mode=WLAN.STA_AP, ssid='Cola', auth=(WLAN.WPA2, 'abc12345678'))
                  wlan.ifconfig(id=1, config=('192.168.10.1, '255.255.255.0', '192.168.10.1', '192.168.10.1'))
                  connect to 'Cola'
                  and ftp(with micro/python) is connecting on 192.168.10.1 but fails on root dir (/flash)
                    livius @Colateral
                    @Colateral
                    I also wait for this but still do not know how to work with it
                    STA work but AP not able to connect
                    https://forum.pycom.io/post/4202
                      robert-hh
                      @Colateral: I tried your setting and it worked fine for both addresses (STA and AP), using command line ftp on Linux. Did you use passive mode? Active mode is not supported.
                        Colateral @robert-hh
                        @robert-hh Yes. It is passive mode. My environment is on Windows10. I tried with WinScp, TotalCommander and Windows10 ftp in passive mode. I saw that is working if I use the default 192.168.4.1 IP instead of the custom IP 192.168.10.1 .
                          robert-hh
                          @Colateral That sounds strange that 192.168.4.1 works, but not 192.168.10.1. The other thing that suprises me is, that you used command line ftp on WIndows 10 in passive mode. The one I have here does not support it. Do you have a special version?
                          C 2 Replies Last reply Reply Quote 0
                            gas @jmarcelino
                            @jmarcelino
                            doesn't this in lower case
                            I tried the lorwan nano but no luck i don't see it connected
                            I changed the WiFi parameters and the use the code snippet to generate the gateway_id (i added .lower())
                            added the gateway on TTN using the same Id
                            but no lock i don't see pull/push arriving to TTN
                            do we need to change the router address too ?
                              livius @robert-hh
                              @robert-hh said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
                              Did you tried WLAN.STA_AP? or separately? WLAN.STA and another try WLAN.AP. Separately it work but not as WLAN.STA_AP.
                              I have tested this and i can not connect to AP in that mode.
                              But i have while True: loop.
                              Inside loop i have machine.idle but this do not help.
                              I see Wipy on the list of networks but can't connect.
                                rskoniec @gas
                                @gas On the TTN gateway configuration you should use router.eu.thethings.network:1700 from config.py @jmarcelino addons generating GATEWAY_ID are OK.
                                  robert-hh
                                  @livius Yes, I used STA_AP mode, and connected without rebooting the LoPy to the STA and AP, one after the other. At the same time it's not possible since only one connection at a time is allowed. But the behaviour was a little bit inconsistent. In active mode, trying the ls command, I got two different error messages, when it should be the same all the time.
                                    Colateral @livius
                                    @livius I tried and STA_AP is working. I am connected with my laptop on AP (ftp getting files) and the WiPy is connected to local server sending data. I replied to your topic ... seems that is missing connect
                                      gas @rskoniec
                                      @rskoniec
                                      Thanks itis exactly what i have
                                      I see push pull but nothing on the TTN
                                      I'm missing something .. not sure where (wifi is connected )
                                        @robert-hh I believe I know what was happening. If you jump from Wipy default AP to the new AP (as STA_AP) having the same MAC and you try to connect Wipy to the wifi router where computer is plugged with the Lan cable... . Windows 10 is going to be confused. After I restarted windows and unplugged the cable everything is working fine.
                                          gas @gas
                                          we are talking at the TTN side right
                                          Description            lopyNanoGW
                                          Status                      not connected
                                          Frequency Plan      Europe868MHz
                                          Router      router.eu.thethings.network:1700
                                          J R 2 Replies Last reply Reply Quote 0
                                            jmarcelino @gas
                                            @gas
                                            On TTN have you registered the gateway as "gateway connector" or "packet forwarder" under Protocol?
                                            You have to register as "packet forwarder"
                                            TTN will also automatically add a 'eui-' prefix to your gateway ID if you chose the correct one.
                                            G 1 Reply Last reply Reply Quote 1
                                            • 5
                                            • 6
                                            • 2 / 6
