    firmware
    113 Posts 34 Posters 92.0k Views 32 Watching
      jmarcelino @gerkez
      @gerkez
      also make sure you have selected the "packet forwarder" protocol when registering the gateway in TTN. I think your ID question may relate to this.
        gerkez @daniel
        @daniel
        Thanks. I'll try it and let you know
          gerkez @jmarcelino
          @jmarcelino
          Hi. Thanks.
          I deleted my gateway and registered a new one with the "packet forwarder" protocol.
          It generates a Gateway ID based on the EUI (eui-70b3d54991ae49e8).
          I tried both ID's in the config.py.
          eui-70b3d54991ae49e8: script runs but the console displays "not connected".
          70b3d54991ae49e8 (without prefix eui-): script runs but restarts all the time.
          Here is my config.py:
          GATEWAY_ID = 'eui-70b3d54991ae49e8' (not working)
          GATEWAY_ID = '70b3d54991ae49e8' (infinite loop, restart)
          SERVER = 'bridge.eu.thethings.network'
          PORT = 1883
          NTP = "pool.ntp.org"
          NTP_PERIOD_S = 3600
          WIFI_SSID = 'my ssid'
          WIFI_PASS = 'my passwd'
          LORA_FREQUENCY = 868100000
          LORA_DR = "SF7BW125" # DR_5
            The correct gateway ID to use is: 70b3d54991ae49e8
            These 2 parameters are incorrect:
            PORT = 1883
            Please use the same as in the example, which are:
            SERVER = 'router.eu.thethings.network'
            PORT = 1700
              gerkez @daniel
              @daniel
              @jmarcelino
              Hi Guys,
              Thanks a lot for helping.
              I have a connection to TTN, but is seems that my lopy reboots all the time (every 30 -60 seconds).
              I hav put a red led for 3 seconds in main.py and I can see this red led light up all the time and than I lose my connection (wiFi as well).
              Hope you have an idea what's going wrong
              L S 2 Replies Last reply Reply Quote 0
                livius @gerkez
                @gerkez
                What you got on UART REPL?
                Put info here - there can be some usefull info
                G 2 Replies Last reply Reply Quote 0
                  gerkez @livius
                  @livius
                  Hello Livius,
                  My pymakr doesn't work. Connection errors.
                  So I use Putty. Problem is that the device reboots all the time, so I don't see anything on the UART REPL
                    livius @gerkez
                    @gerkez
                    Try Arduino IDE -> COM port monitor instead
                    • Z Offline
                      zmrzli @Colateral
                      @Colateral
                      My problem was that password was not long enough. Once I changed it, it worked fine. It would be better if some indication was given about a problem from WiPy, but no big deal, once understood...!
                        gerkez @zmrzli
                        @zmrzli
                        Which password do you mean?
                          Shaun @gerkez
                          @gerkez Are you using a custom base PCB (your own) or are you using the Pycom expansion PCB?
                          I ask, as you may be running into the WiPy resetting due to rf reflections issue.
                            gerkez @Shaun
                            @Shaun
                            I am using a pycom expansion board with LoPy
                              Shaun @gerkez
                              @gerkez Ok, then you should not be experiance problems from rf reflections, and should be able to rule it out.
                              I doubt you are working on a conductive table ;-)
                                gerkez @livius
                                @livius
                                Hello Livius.
                                Here is what I see on my W UART REPL:
                                I (146522) wifi: mode : sta (24:0a:c4:00:84:44)
                                I (146523) wifi: sleep disable
                                I (146650) wifi: n:1 0, o:6 0, ap:255 255, sta:1 0, prof:6
                                I (147638) wifi: state: init -> auth (b0)
                                I (147640) wifi: state: auth -> assoc (0)
                                I (147643) wifi: state: assoc -> run (10)
                                I (147662) wifi: connected with IANNIS, channel 1
                                WiFi connected!
                                Push ack
                                I (157644) wifi: pm start, type:0
                                Pull ack
                                Pull ack
                                Push ack
                                Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
                                Register dump:
                                PC : 0x400f6f9f PS : 0x00060b30 A0 : 0x800d8428 A1 : 0x3ffc5c30
                                A2 : 0x000330d0 A3 : 0x3ffc666c A4 : 0x00000001 A5 : 0x00000000
                                A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800f5ed2 A9 : 0x3ffe96c0
                                A10 : 0x00000001 A11 : 0x00000001 A12 : 0x3ffe21b0 A13 : 0x00000010
                                A14 : 0x3ffe9830 A15 : 0x3ffe9790 SAR : 0x00000013 EXCCAUSE: 0x0000001c
                                EXCVADDR: 0x000330d0 LBEG : 0x400f296c LEND : 0x400f2974 LCOUNT : 0x00000000
                                Backtrace: 0x400f6f9f:0x3ffc5c30 0x400d8428:0x3ffc5c70 0x400d85b8:0x3ffc5c90 0x400d862b:0x3ffc5cb0 0x400d8b38:0x3ffc5ce0 0x400d8d52:0x3ffc5d00 0x400d7eff:0x3ffc5d40
                                Here is a coredump. I haven't copied it.
                                Rebooting...
                                ets Jun 8 2016 00:22:57
                                configsip: 0, SPIWP:0x00
                                mode:QIO, clock div:2
                                load:0x3fff9010,len:8
                                load:0x3fff9018,len:248
                                load:0x40078000,len:4056
                                load:0x4009fc00,len:920
                                entry 0x4009fde4
                                I (1542) wifi: wifi firmware version: 2a22b2d
                                I (1558) wifi: pp_task_hdl : 3ffd72f8, prio:23, stack:8192
                                I (1558) wifi: Init lldesc rx mblock:10
                                I (1558) wifi: Init lldesc rx ampdu len mblock:7
                                I (1560) wifi: Init lldesc rx ampdu entry mblock:4
                                I (1565) wifi: sleep disable
                                I (2553) wifi: frc2_timer_task_hdl:3ffdd348, prio:22, stack:2048
                                I (2574) wifi: mode : softAP (24:0a:c4:00:84:45)
                                MicroPython v1.8.6-493-g99ac80fe on 2017-03-03; LoPy with ESP32
                                  rikkertmark
                                  first of all, the LoraWAN Nano Gateway works great!!
                                  I used the HTTP Intergration of the TTN it post the received data to my PHP script and the PHP script placed the data in my own database.
                                  I have used the HTTP intergration below.
                                  https://www.thethingsnetwork.org/docs/applications/http/
                                  I see that is possible that I can receive also the Latitude, longitude and altitude of the device. without place this in the payload, but this is not implement in python script.
                                  Is it possible to implement this in python without put this values in the raw payload?
                                  "latitude": 52.2345,               // Latitude of the device
                                  "longitude": 6.2345,              // Longitude of the device
                                  "altitude": 2                            // Altitude of the device
                                  Best Regards,
                                  Mark
                                    jp00
                                    Will the nano gateway work with any node or just Lopys? For example, will Multitech's mDot work?
                                    Regards,
                                    Javier
                                      livius @daniel
                                      @daniel
                                      I just upgraded my board and see - but no info about this version
                                      (sysname='WiPy', nodename='WiPy', release='1.6.8.b1', version='v1.8.6-504-gff1098f6 on 2017-03-13', machine='WiPy with ESP32')
                                      also after upgrade i now have:
                                      OSError: I2C bus error
                                        MainSheet @daniel
                                          bihut
                                          In the nanogateway.py file, where is the function const()?. Because const(2), const(1), etc. is not recognized.
                                          Thanks in advance.
                                            robert-hh @bihut
                                            @bihut const() is a kind of Micropython directive, not a function. It's kind of similar to #define in C.
                                            • 5
                                            • 6
                                            • 4 / 6
