    Unhandled exception in interrupt handler
    unhandled excepguru error
    23 Posts 5 Posters 9.8k Views 6 Watching
      danielm
      @paulS
      Thanks, I will try that as a workaround. Anyway it should work with class method as well. Daniel from Pycom promised to take a look at it.
        I have been trying to reproduce the issue with the latest firmware without success. @paulS can you provide another example that shows the issue?
          danielm
          @daniel
          Did you generate enough pulses to increment all three counters? As you can see, in my experiments 22-24k pulses were needed in total to encounter those issues.
            robert-hh @danielm
            @danielm Maybe the problem is somewhere else. The LoPy (and WiPy) use a soft interrupt handler. That means this handler can be interrupted by another event. This event can come from the same source, when the signal, which you count has a slow slope, and slow means rise/fall time >2-3 µs. I had seen this phenomenon without following it in my tests of irq latency, where I had unexpected responses first when using a 'slow' source. Now I made a test, and triggered the lopy with triangle pulses. The code is simple. The ISR just responds with a pulse when triggered. If the slope is slow, is see several pulses.
            Pulse width 3.3 µs, rise/fall time 1.65 µs: Single pulse
            Pulse width 10 µs, rise/fall time 5 µs: Two pulses
            Pulse width 400µs, rise/fall time 200 µs: Four pulses
            Maybe that's a reason for the effect here. I recall an observation, that interrupt handler may be called recursively, if the next event happens, before handling of the first has finished. And with your three timers that may stack up even more, if by chance the event coincide. In another application I used therefore a flag to avoid recursive calls.
            And yes, here is my test code:
            from machine import Pin, idle
            resp_pin = Pin("G11", mode=Pin.OUT)
            resp_pin(1)
            def resp(p, pout = resp_pin):
                pout(0)
                pout(1)
            irq_pin = Pin("G7", mode=Pin.IN, pull=Pin.PULL_UP)
            irq_pin.callback(trigger = Pin.IRQ_FALLING, handler = resp, arg=None)
            try:
                    idle()
            except:
                pass
            irq_pin.callback(handler = None)
              robert-hh @danielm
              @danielm said in Unhandled exception in interrupt handler:
              def counter3irq(self, obj):
              self.temporary2 = self.counter3
              self.counter3 = self.temporary2 + 1
              Not that I think it's the reason, but should'nt that piece of code be:
              		self.temporary3 = self.counter3
              		self.counter3 = self.temporary3 + 1
                danielm
                Yes, of course it should. I was just too quick with copy-paste :)
                Thank you for your previous reply as well. I am not sure how fast are my opto-isolators. I will check with oscilloscope in the beginning of next week.
                  @robert-hh thanks. I'll investigate around your findings today.
                    robert-hh @daniel
                    @daniel I could not find evidence that the simple IRS I used is called recursively. To catch that event, I had set up a global flag, which is set and clear upon entry, and i set upon entry, would increase a global counter, like this:
                    resp_pin(1)
                    flag = False
                    counter = 0
                        global flag, counter
                        if flag:
                            counter += 1
                            flag = True
                            pout(0)
                            pout(1)
                            flag = False
                    That counter stayed 0, even if I extended the time between the two pout() calls.
                    Hy hypothesis is, that the input stage of the esp32 has not Schmitt-Trigger characteristics, and noise in a slow transition causes the input stage to toggle fast. At a slope time of 1ms for instance, I had the ISR called 12 times in a row.
                      danielm
                      If your hypothesis is right and there are no recursively called ISRs could it somehow cause memory issues anyway?
                      Btw, my opto-isolators are quite slow, as one could expect from opto-isolators... Rise time is around 23us.
                        robert-hh @danielm
                        @danielm I'm not saying, that this does not happen, only my test did not reveal it. What is even more likely, that with your three ISR functions you have the chance of stacked calls. Daniel wanted to look into it. I have just one signal generator, but I could set up another micro to generate pulses.
                        But in any case you have to deal with multiple calls form that single source. Didn't you see increments of your counter faster than excepted? In order to shape the signal, you could add a Schmitt-Trigger gate, like the 74HC14. You could also try the falling edge of your opto-isolator, which should be faster.
                          robert-hh @robert-hh
                          @robert-hh I managed to make the test with at least two signals (the signal generator has two channels!). SO I could test all variants of slow vs. fast pulses, pulses at the same time and pulses properly apart. I've set the pulse frequency to 100Hz. Setting the delays I could fine shift the two pulses in relation to each other, so that they happened either at the same time or with some µs distance. And I modified my test code to register two signals and to detect, when the ISR for one signal is interrupted by the one for the other signal. That never happened, the code never crashed. Only when I pushed Ctrl-C to end the test, I got sometimes a core dump, and the probability of that seems to depend on the chance, that the test program is interrupted in a critical state, so the increasing probability was.
                          • single source fast pulse (lowest)
                          • single source slow pulse or double source fast pulse
                          • double source slow pulse (highest)
                          Test code:
                          resp_pin1 = Pin("G11", mode=Pin.OUT)
                          resp_pin1(1)
                          resp_pin2 = Pin("G13", mode=Pin.OUT)
                          resp_pin2(1)
                          flag1 = False
                          flag2 = False
                          count1 = 0
                          count2 = 0
                          def resp1(p, pout = resp_pin1):
                              global flag2, flag1, count1
                              flag1 = True
                              if flag2:
                                  count1 += 1
                              pout(0)
                              pout(1)
                              flag1 = False
                          def resp2(p, pout = resp_pin2):
                              global flag2, flag1, count2
                              flag2 = True
                              if flag1:
                                  count2 += 1
                              pout(0)
                              pout(1)
                              flag2 = False
                          def run(flag = True):
                              irq_pin1 = Pin("G7", mode=Pin.IN, pull=Pin.PULL_UP)
                              irq_pin2 = Pin("G9", mode=Pin.IN, pull=Pin.PULL_UP)
                              irq_pin1.callback(trigger = Pin.IRQ_RISING, handler = resp1, arg=None)
                              if flag:
                                  irq_pin2.callback(trigger = Pin.IRQ_RISING, handler = resp2, arg=None)
                              try:
                                      idle()
                              except:
                                  print("%5d %5d" % (count1, count2))
                                  irq_pin1.callback(handler = None)
                                  irq_pin2.callback(handler = None)
                            livius @robert-hh
                            can you show how that signals looks like
                            maybe characteristic of raising and falling edge matters (how fast raise and how fast falling
                            or maybe @danielm have some noise in real signal?
                              robert-hh @livius
                              @livius If you scroll down and read in this post, you'll see the answers to your questions, and also has @daniel already expressed interest in this topic. For the last test I used the rise time seen bye @danielm.
                              Using the pulse mode of my signal generator with transition times of about 7 ns the multiple interupts do not occur. B.T.W.: I had a similar effect on the ESP8266 with slow pulses. Very nasty!
                                @robert-hh thanks for the super detailed analysis! Can you share how did you solve this issue on the ESP8266?
                                  robert-hh @danielm
                                  @danielm @livius Until now I was testing with a symmetric triangle pulse of 50 µs duration. I switched now to a exp-rise pulse, with a rise time of ~25 µs. Funny enough, the double pulse disappeared, until I changed to trigger on the falling edge. I had made the same observation with other asymmetric pulses. The red trace is the input pulse for the green response. I cannot extend the pulse independently form the rise time without creating my own pulse shapes, which somehow fails with the vendors software (Windows only, with missing NI libs).
                                    robert-hh @daniel
                                    @daniel Actually it were two different cases:
                                    a) Timer interrupt. If the handler took longer than about 500 µs, the handler seemed to be raised a second time. Solved by a flag in the handler, which checked whether it was already busy.
                                    b) External interrupt, which was called twice in a row. Solved by using a different drive with faster slopes..
                                      @robert-hh thanks. Could the solution here be to disable GPIO interrupts while the C handler is executing (this is fast)?
                                        livius @daniel
                                        @daniel
                                        Then we can miss interrupt on different pin?
                                        Or you mean interrupt on exact pin?
                                          @livius I mean to disable the interrupt on that same pin.
                                            livius @daniel
                                            @daniel
                                            it looks like good concept - not overlapped events
