    Interrupt button debounce with long / short press
    15 Posts 5 Posters 5.5k Views 7 Watching
      crankshaft @mohpor
      @mohpor - Thanks for helping, but I get multiple short presses (1 to 6) even if I increase the t > 100.
      Am also getting a crash:
      Short 0
      Short 0
      Guru Meditation Error of type LoadProhibited occurred on core  0. Exception was unhandled.
      Register dump:
      PC      : 0x40081b87  PS      : 0x00060330  A0      : 0x800de62b  A1      : 0x3ffe15f0
      A2      : 0x65642728  A3      : 0x3ffc39d8  A4      : 0x3ffe1a40  A5      : 0xd58eb6e0
      A6      : 0x3ffe16f8  A7      : 0x0000005b  A8      : 0x80083f91  A9      : 0x3ffe15b0
      A10     : 0x00000003  A11     : 0x00060723  A12     : 0x00060723  A13     : 0xb33f0000
      A14     : 0xb33fffff  A15     : 0x3ffe16c0  SAR     : 0x00000002  EXCCAUSE: 0x0000001c
      EXCVADDR: 0xd58eb6e0  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
      Backtrace: 0x40081b87:0x3ffe15f0 0x400de62b:0x3ffe1610 0x400ecec0:0x3ffe1630 0x400e95a8:0x3ffe1650 0x400e9615:0x3ffe1670 0x400e2905:0x3ffe1690 0x400e047c:0x3ffe16d0 0x400f325a:0x3ffe16f0 0x400ecea1:0x3ffe1710 0x400e95a8:0x3ffe1730 0x400e9615:0x3ffe1750 0x400f4b68:0x3ffe1770 0x400ecfcd:0x3ffe1810 0x400e95a8:0x3ffe1850 0x400e95ec:0x3ffe1870 0x400dbf50:0x3ffe18a0 0x400e071f:0x3ffe18c0 0x400d7e80:0x3ffe1940
        Rebooting...
      ets Jun  8 2016 00:22:57
      rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0x00
      I added a print(t) after t = chrono.read_ms() so I could monitor the time, and pressed the button quickly and got 3 hits all with the same timestamp:
      >>> execfile('dev.py')
      Ram Free: 84.40%
      waiting...
      0.0
      182.9711
      Short 0
      182.9711
      Short 0
      182.9711
      Short 0
        mohpor
        @crankshaft That's strange, I have been using this code for more than 2 weeks now, without a single double press or any crashes! What are using as button? A micro switch?
          crankshaft @mohpor
          @mohpor - it's one of those common, small through-hole tactile buttons, but anyway I have your code working now with what appears to be 100% reliability and no double presses:
          I added a check for last value and ignored it if received:
          last = 0
          def btn_press_detected(btn):
            global chrono, timer, last
            try:
              val = btn.value()
              if 0 == val:
                chrono.reset()
                chrono.start()
                timer.callback(long_press_handler)
                timer.callback(None)
                chrono.stop()
                if(t==last): return
                last = t
                if (t > 30) & (t < 200):
                  single_press_handler()
            finally:
              gc.collect()
          Thanks so much for your help, although it does seem incredibly long-winded to achieve this when the same thing can be done on the RPI pins with a built in debounce option !
            mohpor
            @crankshaft
            Happy to help and glad it's over.
            100% agreed on the comment, if the button is debounced, that's two less interrupt handlers required and at least some bytes freed from memory.
            M.
              livius @crankshaft
              @crankshaft
              good to see that you finally solve it
              but i have question - because i saw this behavior self when i have too big/too small pullup/pulldown.
              Do you use internal pin pullup or pull down. Or do you use external resistor? If external - what value?
              EDIT
              +1 for debounce option
              add it to:
              https://forum.pycom.io/topic/433/features-wish-list
                crankshaft
                I came up with another version that also works:
                def long(count):
                   print('Long Press',count)
                def short(count):
                   print('Short Press',count)
                count = 0
                butms = 0
                def btn_press_detected(pin):
                  global butms, count
                  now = time.ticks_ms()
                  if butms == 0: butms = now
                    if butms == now: return
                  i = 0
                  while i < 10:
                    time.sleep_ms(1)
                    if pin() == 1: i = 0
                    else: i+=1
                  while pin() == 0:
                    i+=1
                    if(i > 1000): break
                    time.sleep_ms(1)
                  count +=1   ## debug check for double-trigger only
                  if(i>1000): long(count)
                  else: short(count)
                  crankshaft
                  In case anyone is interested I created a class:
                  from time import sleep_ms, ticks_ms
                  from machine import Pin
                  import gc
                  class BUTTON:
                    def __init__(self,pid='P12',longms=1000):
                      self.longms = longms
                      self.butms = 0
                      self.pin = Pin(pid, mode=Pin.IN, pull=Pin.PULL_UP)
                      self.pin.callback(Pin.IRQ_FALLING | Pin.IRQ_RISING,  self.press)
                    def long(self):
                      pass
                    def short(self):
                      pass
                    def press(self,pin):
                      now = ticks_ms()
                      if self.butms == 0: self.butms = now
                        if self.butms == now: return
                      i = 0
                      while i < 10:
                        sleep_ms(1)
                        if self.pin() == 1: i = 0
                        else: i+=1
                      while self.pin() == 0:
                        i+=1
                        if(i > self.longms): break
                        sleep_ms(1)
                      if(i>1000): self.long()
                      else: self.short()
                      while self.pin() == 0: pass
                      gc.collect()
                  And to call it:
                  def short():
                    print('short')
                  def long():
                    print('long')
                  import button
                  but = button.BUTTON()
                  but.short = short
                  but.long = long
                  G 1 Reply Last reply Reply Quote 1
                    crankshaft @livius
                    @livius - I am using internal pullup, I could also add a decoupling capacitor across the switch but I wanted to do it all in software instead.
                      gael-wogenstahl @crankshaft
                      @crankshaft
                      Hello !
                      I've tried to use your class with 3 different buttons but it seems once a button interrupt is triggered, all other buttons interrupts don't work anymore and only the future interrupts from the first pressed button are triggered.
                      I've been searching a lot for an explanation but couldn't find any.
                      Did you experience that kind of behavior ? Do you have a clue as to where that can come from ?
                      Thanks for your help !
                        livius @gael-wogenstahl
                        @gael-wogenstahl
                        can you show how you declare all?
                        Code for three buttons?
                          gael-wogenstahl @livius
                          @livius
                          here are the BUTTON class code (slightly modified from your version, mainly to add comments)
                          from time import sleep_ms, ticks_ms, ticks_diff
                          from _thread import start_new_thread
                          import gc
                          class BUTTON:
                            def __init__(self, pid='P10', longms=1000):
                              self.pressms = 0
                            def long(self):
                              pass
                            def short(self):
                              pass
                            def press(self, pin):
                              # If never pressed, store press time
                              if self.pressms == 0: self.pressms = ticks_ms()
                                # If pressed within 500 ms of first press, discard (button bounce)
                                if ticks_diff(self.pressms, ticks_ms()) < 500: return
                              # Wait for value to stabilize for 10 ms
                              i = 0
                              while i < 10:
                                sleep_ms(1)
                                else: i+=1
                              # Measure button press duration
                                i+=1
                                sleep_ms(1)
                              # Trigger short or long press
                                start_new_thread(self.long, ())
                                start_new_thread(self.short, ())
                              # Wait for button release
                              self.pressms = 0
                              gc.collect()
                          and here is the code I use to instantiate the different buttons
                          import button
                          def short_red():
                            print('Short red button press')
                          def long_red():
                            print('Long red button press')
                          def short_yellow():
                            print('Short yellow button press')
                          def long_yellow():
                            print('Long yellow button press')
                          def short_black():
                            print('Short black button press')
                          def long_black():
                            print('Long black button press')
                          red_button = button.BUTTON(pid='P22',longms=500)
                          red_button.short = short_red
                          red_button.long = long_red
                          yellow_button = button.BUTTON(pid='P21',longms=500)
                          yellow_button.short = short_yellow
                          yellow_button.long = long_yellow
                          black_button = button.BUTTON(pid='P10',longms=500)
                          black_button.short = short_black
                          black_button.long = long_black
                            mahe @gael-wogenstahl
                            @gael-wogenstahl
                            I'm experiencing the same kind of problems - did you ever solve it?
