Onewire DS18B20P
  • Wiring WiPy ver. 2.0 with DS18B20P
    1 - # DS18B20P data line connected to WiPy pin P10
    * DS18B20P - parasite mode wiring
    A - # * DS18B20P GND pin connected to DS18B20P Vin pin
    2 - # * DS18B20P GND pin connected to WiPy GND
    B - # * in series to DS18B20P/WiPy data line connection point
    3 - # * mount an 1 Kohm resistor that will be connected to WiPy 3V3
    In micropython example code I have divided by 100
    the reading value to obtain the right temperature value
             print(temp.read_temp_async()/100) # added /100
    ** see the attachment : WiPi2_DS18B20P_readings.jpg
    If I am right the tutorial example must be upgraded
    https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/onewire.html?highlight=onewire
    One-wire driver
    This tutorial explains how to connect and read data from a DS18x20 temperature sensor.
    Basic usage
    from machine import Pin
    from onewire import DS18X20
    from onewire import OneWire
    #DS18B20 data line connected to pin P10
    ow = OneWire(Pin('P10'))
    temp = DS18X20(ow)
    print(temp.read_temp_async()/100) # added /100 to have Celsius degrees
    time.sleep(1)
    temp.start_convertion()
    time.sleep(1)
1 out of 1
