    BLE connects but connection is lost immediately
    blewipy2.0connectivity
    4 Posts 2 Posters 1.5k Views 2 Watching
    • salvoaerodevS Offline
      salvoaerodev
      I wrote a simple script to discover a device with a fixed adv complete name, and connect to this device with his MAC address. After found it i need to connect to that device and discover services and characteristics, but after the connection i get a GATT object and connection closes when i try to discover his services.
      I verified the connection on my BLE device. The connection started normally. Anyway when i call the
      bluetooth.isconnected()
      it fails and on my console i do not get the error message i wrote for that condition.
      The full code i wrote is here
      import binascii
      from network import Bluetooth
      bluetooth = Bluetooth()
      bluetooth.start_scan(10)    # start scanning with no timeout
      while bluetooth.isscanning():
          adv = bluetooth.get_adv()
          if(adv != None):
              name = bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)
              print(name)
              if(name == 'xDev-FF:A1:B0-M01'):
                  mac_address = binascii.hexlify(adv.mac)
                  print("MAC: "+ str(mac_address))
                  print("DATA: {}".format(binascii.hexlify(adv.data)))
                  conn = bluetooth.connect(adv.mac)
                  if(conn.isconnected()):
                      print("Connection opened!")
                  print("Connected to device with addr = {}".format(binascii.hexlify(adv.mac)))
                  services = conn.services()
                  print("Service List")
                  for service in services:
                      time.sleep(0.050)
                      print(service)
      And here the log
      xDev-FF:A1:B0-M01
      MAC: b'f10403020100'
      DATA: b'020106120978444f4d2d46463a41313a42302d4d3031020afe000000000000'
      Connected to device with addr = b'f10403020100'
        File "<stdin>", line 18, in <module>
      OSError: connection already closed
        Arkaik
        Hi, I had the same problem, which firmware version are you using?
        Personnaly I was using 1.6.12.b1.
        Following this topic I found that downgrading to 1.4.0.b1 works.
        Hope it helps.
          salvoaerodev
          It's your same firmware @Arkaik, so probably it's a bug introduced with 1.6.12.b1. I will try to downgrade too. Thanks for your support and let's keep in touch for next updates on BLE.
            Arkaik @salvoaerodev
            @salvoaerodev Sure, I hope this bug will be fixed soon as it could be nice to reupgrade firmware for already fixed bugs.
