    Bluetooth WiPy client connecting to WiPy peripheral
    bluetooth
    10 Posts 5 Posters 4.3k Views 5 Watching
      lcgeldenhuys
      I have a WiPy setup as a BLE peripheral as per the example:
      import binascii
      from network import Bluetooth
      from machine import Timer
      bt_periph = Bluetooth()
      bt_periph.set_advertisement(name = 'mag_test', service_uuid = b'1234567890123456')
      def conn_cb (bt_o):
          events = bt_o.events()
          if  events & Bluetooth.CLIENT_CONNECTED:
              bt_o.advertise(False)
              print("Client connected")
              bt_o.advertise(True)
              print("Client disconnected")
      bt_periph.callback(trigger = Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler = conn_cb)
      bt_periph.advertise(True)
      srv_test = bt_periph.service(uuid = b'1234567890123456', isprimary = True, nbr_chars = 1)
      blaster = srv_test.characteristic(uuid = b'ab34567890123456', properties = Bluetooth.PROP_READ, value = 55)
      def blaster_cb(chr):
          print("Read request, returning value = {}".format(blaster.value()))
      blaster_cb = blaster.callback(trigger = Bluetooth.CHAR_READ_EVENT, handler = blaster_cb)
      I also have a WiPy setup as a client, trying to connect so I can read the service characteristic. However, whilst the peripheral is telling me that the client is connected, the client tells me that it is not:
      import binascii
      bt_client = Bluetooth()
      bt_client.start_scan(-1)
      	adv = bt_client.get_adv()
      	if adv and bt_client.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'mag_test':
      		print ("Found mag test peripheral")
      		print("RSSI : {}, MAC : {}".format(adv.rssi, binascii.hexlify(adv.mac)))
      		bt_client.stop_scan()
      		try:
      			conn = bt_client.connect(adv.mac)
      			while not conn.isconnected():
      				time.sleep(0.100)
      			print("Connected...")
      			services = conn.services()
      			for service in services:
      				time.sleep(0.300)
      				if type(service.uuid()) == bytes:
      					print('Reading characteristics from service = {}'.format(service.uuid()))
      					print('Reading characteristics from service = %x' % service.uuid())
      				chars = service.characteristics()
      				while conn.isconnected():
      					for idx, char in enumerate(chars):
      						if (char.properties() & Bluetooth.PROP_READ):
      							print("char.read : {}".format(char.read()))
      						time.sleep(1.000)
      			print("Disconnected...")
      			break
      		except Exception as ex:
      			print("Exception caught...")
      			print(ex)
      		time.sleep(0.050)
      The conn.isconnected() never returns True, despite the peripheral reporting a connection. I know the connection works, because I can connect and read the characteristic value with a smartphone application.
      If I ignore the False connection state and try to create a services object anyway services = conn.services() then an exception is generated with "connection is already closed"
      Any help for troubleshooting / hunting down the cause would be greatly appreciated.
      Lourens
        lcgeldenhuys
        Also, tried using the example client code to connect to other peripherals, e.g. the Tile. Same behaviour, namely a mobile app (specifically https://itunes.apple.com/us/app/lightblue-explorer-bluetooth/id557428110?mt=8) is able to connect and interrogate the services and characteristics, but the WiPy fails.
        Using current firmware 1.6.5.b1
          lcgeldenhuys
          I downgraded to 1.4.0.b1 as I was sure this worked some time ago, and indeed, it works again!
          • I Offline
            Innocenzo @lcgeldenhuys
            @lcgeldenhuys So the problem is the WiPy firmware? I actually use the release 1.6.7.b1 and your code does not work.
            There is a fix for that or the only way to perform a BLE connection is to downgrade the firmware?
              jmarcelino
              I understand you're re-trying to connect but triggering a new connection ( conn = bt_client.connect() ) ten times a second sounds like a bad idea to me. I can't see why you'd have to do that but I'll do some tests later today.
              • I Offline
                Innocenzo @jmarcelino
                @jmarcelino I try also to increase the sleep time (a connection every 2 seconds) but the problem persists
                • I Offline
                  Innocenzo
                  When power up the BLE I Have this messages:
                  BTDM CONTROLLER VERSION: 010101
                  BTDM ROM VERSION 0101
                  BD_ADDR: 24:0A:C4:XX:XX:XX
                  NVDS MAGIC FAILED
                  RF Init OK with coex
                  Enable Classic BT
                  Enable Low Energy
                    jmarcelino @Innocenzo
                    @Innocenzo
                    That's OK. As we all know there is no magic, only great science and engineering. ;-)
                    Seriously now, we all get that message it's related to storage of BLE bonding keys in the NVS ( non-volatile storage ) area which isn't ready yet. Nothing to worry about.
                    • Y Offline
                      yunying
                      I have the same problem with two Lopy, I lose connection immediately:)
                        daniel
                        Thanks for pointing out this bug. It has been fixed on the latest release 1.7.1.b1.
                        Cheers,
                        Daniel
