    Pymakr Atom Plugin released
    pymakrpluginatom
    91 Posts 29 Posters 65.9k Views 26 Watching
      Ralph @MaSePreetz
      @MaSePreetz You are right, the behaviour is a little less straight forward. Turns out Atom stores this state per project. So if you have one project open, close the terminal and then close atom, the terminal will still be closed when opening that same project. But when opening another project, the state will be set to 'open' again.
      Considering that, it might be useful for some people to have a 'don't open on startup' setting for the plugin, so it will always stay closed by default.
        robmarkcole
        Hi @Ralph I see you have a lot on your plate, but I wonder if it will also be possible to one day program via a Jupyter notebook? This would be fantastic for rapid expolration of data generated by the board.
        Of interest https://github.com/adafruit/jupyter_micropython_kernel
          tuxtof
          Same problem for me
          0_1492846714191_upload-6fcc324a-8297-44d7-90de-abf0717b00be
          MacOS X 10.12.4
          Atom 1.16.0
          Pymakr 0.9.3
          Lopy FW 1.6.12.b1
          any other solution to use my Lopy ?
            livius @tuxtof
            @tuxtof
            First test if your ping reach device
            show us response
            ping 192.168.4.1
              tuxtof @livius
              @livius
              ping is OK
              telnet is working
              i can connect on the python interpreter with the default login / password
              only Atom/Pymakr is not working
              @pycom please help
                pwest @smssms
                @smssms Same problem on Linux Mint 17.3, Cinnamon, 64-bit
                  Ralph @pwest
                  @pwest @smssms If you have time, please test the code on the develop branche on github (instructions for manual installation are in the readme file on the develop branch). This code contains pre-compiled versions of the serialport lib for both mac and linux (64 bit), which should solve both of your issues.
                  Let me know if it works.
                    cylex
                    Hey there! So after testing the plugin for a few days I have to remark that debugging with the pymakr Plugin is quite hard. When it comes to an error the compiler output is often times incomplete and changes after running the same error-having code for several times... However, the compiler output is complete when I use my terminal.
                      bnjroos
                      On windows 10 I cannot see any package named pymakr when searching in the installation tab and when i try to install it manually i get thee following:
                      How to install the pymakr plugin sucessfully ?
                      B R 2 Replies Last reply Reply Quote 0
                        Ralph @cylex
                        Hi @cylex, The same problem (in a different form) was reported in this topic and the bug was fixed (on the develop branch only, not yet released). Very likely this fix also solves your issue. You can do a manual install from the develop branch to test it if you want, or wait for the next release.
                          bnjroos @bnjroos
                          @bnjroos said in Pymakr Atom Plugin released:
                          Found the solution by running npm install inside the package folder.
                            Ralph @bnjroos
                            Hi @bnjroos, Good to hear! For future reference, there is a short instruction for 'manual install' in the readme file on the develop branch
                              bnjroos @Ralph
                              @Ralph said in Pymakr Atom Plugin released:
                              Yes but on windows I don't have apm installed by default hehehe. Maybe a 'npm install' should be added to the manual.
                                Andrea Filippini @bnjroos
                                @bnjroos you can find apm in the Atom install location, under /bin folder
                                  bnjroos @Andrea Filippini
                                  @Andrea-Filippini thank you for the info, i usually use sublime or Visual Studio Code, I am pretty new to Atom.
                                    Ralph
                                    Version 0.9.4 has been released with a few bugfixes and stability improvements:
                                    • Include precompiled serialport libs for mac and linux
                                    • Improved error handling and stability on sync
                                    • Running files is now possible for unsaved files
                                    • Bugfixes for pasting multiple lines and cmd-c/cmd-v commands.
                                    • Fixed connection issue when using telnet to a device's access point
                                    O 2 Replies Last reply Reply Quote 2
                                    • O Offline
                                      obviate @Ralph
                                      @Ralph Hi Ralph, I installed 0.9.4 and upgraded firmware on my LoPy modules to 1.6.13.b1 and now I can't sync using a serial connection. It was OK with 0.9.3 but I don't know whether to blame the firmware or the Atom plugin update. I am running Atom on a Windows 7 x64 PC.
                                      • O Offline
                                        obviate @Ralph
                                        @Ralph I re-built the filesystem on each LoPy and now the sync is working. All good.
                                          Ralph
                                          V1.0.0 has just been released. A few problems concerning the synchronize feature using a serial connection are now solved and some new features have been added:
                                          • Added project specific settings
                                          • Added serial port detection (in sub-navigation under the 'more' button)
                                          • Multiple bug fixes for synchronization over serial
                                          • Terminal height now resizable by dragging the top edge
                                          • Fixed 'failed to connect' bug when reconnecting on telnet
                                          The project specific settings might need some explanation:
                                          When clicking the new 'project settings' option, a config file is created inside your project folder. Any settings changed inside this file will override the global settings. This can be useful when you are using different project for different devices or when each project has a different folder that has to be synchronized.
                                          Remove the settings from this file that you don't want to override.
                                            mcook @Ralph
                                            @Ralph
                                            Maybe I am doing something dumb. When I set up the Atom plugin, by going to Atom > Preferences > Packages > Pymakr, all I see is the PyMakr Readme.
                                            This is what I see... I don't see a place to configure the IP Address of the LoPy.
                                            Any idea what I am doing incorrectly?
                                            Mike
                                            0_1496924816310_upload-695f7c17-dac2-45e2-a8ee-f5c0b3682d28
                                            • 5
                                            • 2 / 5
