    Pymakr Atom Plugin released
    pymakrpluginatom
    91 Posts 29 Posters 65.9k Views 26 Watching
      Ralph @cylex
      Hi @cylex, The same problem (in a different form) was reported in this topic and the bug was fixed (on the develop branch only, not yet released). Very likely this fix also solves your issue. You can do a manual install from the develop branch to test it if you want, or wait for the next release.
        bnjroos @bnjroos
        @bnjroos said in Pymakr Atom Plugin released:
        On windows 10 I cannot see any package named pymakr when searching in the installation tab and when i try to install it manually i get thee following:
        How to install the pymakr plugin sucessfully ?
        Found the solution by running npm install inside the package folder.
          Ralph @bnjroos
          Hi @bnjroos, Good to hear! For future reference, there is a short instruction for 'manual install' in the readme file on the develop branch
            bnjroos @Ralph
            @Ralph said in Pymakr Atom Plugin released:
            Yes but on windows I don't have apm installed by default hehehe. Maybe a 'npm install' should be added to the manual.
              Andrea Filippini @bnjroos
              @bnjroos you can find apm in the Atom install location, under /bin folder
                bnjroos @Andrea Filippini
                @Andrea-Filippini thank you for the info, i usually use sublime or Visual Studio Code, I am pretty new to Atom.
                  Ralph
                  Version 0.9.4 has been released with a few bugfixes and stability improvements:
                  • Include precompiled serialport libs for mac and linux
                  • Improved error handling and stability on sync
                  • Running files is now possible for unsaved files
                  • Bugfixes for pasting multiple lines and cmd-c/cmd-v commands.
                  • Fixed connection issue when using telnet to a device's access point
                  O 2 Replies Last reply Reply Quote 2
                  • O Offline
                    obviate @Ralph
                    @Ralph Hi Ralph, I installed 0.9.4 and upgraded firmware on my LoPy modules to 1.6.13.b1 and now I can't sync using a serial connection. It was OK with 0.9.3 but I don't know whether to blame the firmware or the Atom plugin update. I am running Atom on a Windows 7 x64 PC.
                    • O Offline
                      obviate @Ralph
                      @Ralph I re-built the filesystem on each LoPy and now the sync is working. All good.
                        Ralph
                        V1.0.0 has just been released. A few problems concerning the synchronize feature using a serial connection are now solved and some new features have been added:
                        • Added project specific settings
                        • Added serial port detection (in sub-navigation under the 'more' button)
                        • Multiple bug fixes for synchronization over serial
                        • Terminal height now resizable by dragging the top edge
                        • Fixed 'failed to connect' bug when reconnecting on telnet
                        The project specific settings might need some explanation:
                        When clicking the new 'project settings' option, a config file is created inside your project folder. Any settings changed inside this file will override the global settings. This can be useful when you are using different project for different devices or when each project has a different folder that has to be synchronized.
                        Remove the settings from this file that you don't want to override.
                          mcook @Ralph
                          @Ralph
                          Maybe I am doing something dumb. When I set up the Atom plugin, by going to Atom > Preferences > Packages > Pymakr, all I see is the PyMakr Readme.
                          This is what I see... I don't see a place to configure the IP Address of the LoPy.
                          Any idea what I am doing incorrectly?
                          Mike
                          0_1496924816310_upload-695f7c17-dac2-45e2-a8ee-f5c0b3682d28
                            bucknall @mcook
                            Hi @mcook,
                            If you look at the bottom of the Atom window, you'll see a new bar with a button that says '^ Open'. If you click this, you will see the new terminal interface.
                            Developer Evangelist - Pycom
                            • RobTuDelftR Offline
                              RobTuDelft
                              With one of the previous versions I encountered a serious error, Atom wouldn't even start anymore. So I deinstalled Pymakr.
                              However when I now install it again (tried multiple times) it won't show up anymore. Toggle console does nothing. I can see Pymakr in the packages menu (top menu bar) and I also see it in the Installed Packages menu, where you can change the port etc.
                              Atom is updated to the latest version. Maybe I need to clear some old files?
                              Hackster | About me
                                mcook @bucknall
                                @bucknall
                                Thanks. I see what the issue is.... there is a small red bug in the bottom right corner of the screen. When clicking on it, it indicates that there is an issue with my serial library. It has a "rebuild" link. After clicking on it, and restarting Atom, it now works.
                                Mike
                                  RobTuDelft
                                  Clicking on that bug also gave me some hints: Some installed packages could not be loaded because they contain native modules that were compiled for an earlier version of Atom.Rebuild Packages and clicking rebuild: The system cannot find the path specified, it fails.
                                  edit: third time it worked!
                                  Hackster | About me
                                    amartinez Pybytes Beta
                                    I' m always having problems to sync with the boards, specially while connecting by WiFi it's almost impossible to sync or run a program.
                                    I have everything updated and using Windows10, am I the only one? Or is it "normal"? What do you recommend me to sync easier? Is it possible to connect with Putty by Wifi?
                                      Ralph
                                      A small patch has just been released under v1.0.2. It contains some fixes that will help pytrack/pysense users, for example when the board goes into sleep. The serial will now handle a loss and recovery of the serial port when the board goes to sleep.
                                      • Added timeout and reconnect logic on serial connection (useful for pysense/pytrack sleep)
                                      • Pysense/pytrack serialport detection
                                      • Bugfix related to project settings not refreshing (issue #23)
                                      • Ignoring hidden and empty subfolders during synchronize
                                        Ralph
                                        This morning a patch has been released under v1.0.3.
                                        It fixes issues with serialport library on windows32 and problems in newer atom versions (1.17.2 and 1.18). If you had any installation issues before, this update should to resolve it.
                                        • O Offline
                                          ozeta @Ralph
                                          @Ralph I have atom 1.18 and before pymakr 1.0.3 all worked fine. after last update I get: "Failed to load the Pymakr package" ... stacktrace.... then: The error was thrown from the Pymakr package. This issue has already been reported.
                                          View Issue ( https://github.com/pycom/pymakr-atom/issues/1 )
                                          is it possible to revert to 1.0.2?
                                            Manuel @ozeta
                                            @ozeta I have the same problem in 2 windows 10 machines (64 bits).
                                            Using this https://forum.pycom.io/topic/1137/downgrade-atom-pymkr-plugin should fix the problem.
                                            Try with "apm install Pymakr@1.0.2" in cmd or PowerShell (if you are using windows). It worked for me.
                                            • 5
                                            • 3 / 5
