    Problem pairing OTAA Node to nano gateway in US TTN
    lopyttnttn gateway
    9 Posts 2 Posters 3.1k Views 3 Watching
    • I Offline
      iotmaker
      The nano gateway says it is connected...
      I have configured like this :
      config.py
      LORA_FREQUENCY = 915100000
      LORA_DR = "SF7BW125"   # DR_5
      nanogateway.py
      RX_PK = {"rxpk": [{"time": "", "tmst": 0,
                         "chan": 0, "rfch": 0,
                         "freq": 915.1, "stat": 1,
                         "modu": "LORA", "datr": "SF7BW125",
                         "codr": "4/5", "rssi": 0,
                         "lsnr": 0, "size": 0,
                         "data": ""}]}
      Otaa Node
      for channel in range(0, 72):
          lora.remove_channel(channel)
      lora.add_channel(0, frequency=915100000, dr_min=0, dr_max=4)
      I have not been able to make it join... any suggestions or things that i might be missing?
        jmarcelino @iotmaker
        @iotmaker
        Not sure if this is the problem, but according to the TTN band plan for US915, 915.1Mhz isn't a valid frequency, try 903.9
        I take it you've also changed config.py to SERVER = 'router.us.thethings.network' ?
        • I Offline
          iotmaker
          thanks.. i will try to update the frequencies and try again...
          • I Offline
            iotmaker @jmarcelino
            @jmarcelino said in Problem pairing OTAA Node to nano gateway in US TTN:
            903.9
            no luck.. my nano gateway is connected according to TTN but cant see the node..
              @iotmaker
              What do you have in your OTAA node code for this?
              # set the LoRaWAN data rate
              SO_DR should be 3 instead of 5 for the US915 region.
              Also see the previous thread: https://forum.pycom.io/topic/983/otaa_node-py-error
              • I Offline
                iotmaker
                @jmarcelino this is my node code
                did the change but still no luck...
                from network import LoRa
                import binascii
                import struct
                # create an OTA authentication params
                dev_eui = binascii.unhexlify('xxx'.replace(' ',''))
                app_eui = binascii.unhexlify('xxx'.replace(' ',''))
                app_key = binascii.unhexlify('xxx'.replace(' ',''))
                for index in range(0, 8):
                    lora.remove_channel(index)
                for index in range(16, 65):
                for index in range(66, 72):
                # set the 3 default channels to the same frequency (must be before sending the OTAA join request)
                lora.add_channel(0, frequency=903900000, dr_min=0, dr_max=3)
                lora.add_channel(1, frequency=903900000, dr_min=0, dr_max=3)
                lora.add_channel(2, frequency=903900000, dr_min=0, dr_max=3)
                # join a network using OTAA
                while not lora.has_joined():
                    time.sleep(2.5)
                    print('Not joined yet...')
                print("passed joined")
                # remove all the non-default channels
                for i in range(3, 16):
                    lora.remove_channel(i)
                # create a LoRa socket
                # make the socket blocking
                s.setblocking(False)
                time.sleep(5.0)
                for i in range (200):
                    s.send(b'PKT #' + bytes([i]))
                    time.sleep(4)
                    rx = s.recv(256)
                    if rx:
                        print(rx)
                    time.sleep(6)
                Mi config.py looks like this
                """ LoPy LoRaWAN Nano Gateway configuration options """
                GATEWAY_ID = '70B3D5499BFD0F7A'#
                PORT = 1700
                NTP = "pool.ntp.org"
                NTP_PERIOD_S = 3600
                WIFI_SSID = 'xxx'
                WIFI_PASS = 'xxxx'
                LORA_FREQUENCY = 903900000
                LORA_DR = "SF9BW125"   # DR_3
                  @iotmaker
                  OK I see some issues. Your node code is a bit strange, you don't need to assign the same frequency to three channels, that's only for the EU868 region where the 3 channels are enforced by the spec. Use something like this instead:
                  lora.add_channel(0, frequency=903900000, dr_min=0, dr_max=4)
                  and nothing else, no more add_channels or remove_channels after this.
                  s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3) is OK
                  On the Gateway config change:
                  LORA_DR = "SF9BW125" to
                  Data rate (DR) 3 in the US915 region means SF 7 125Khz (these data rate numbers assignments have different meanings from EU868 region, see the LoRaWAN Regional Parameters specification)
                  This meant the gateway was listening for SF9 (SF set by that string) while your node was sending as SF7 (set by SO_DR = 3) and explains why you get nothing.
                  If all this still fails try setting up the node as ABP instead of OTAA, sometimes the receive window timings for OTAA are hard to achieve.
                  • I Offline
                    iotmaker
                    @jmarcelino
                    Changed to ABP and now the gateway is receiving traffic...
                    thanks... will post my code once i do cleanup :)
                    thanks for your help @jmarcelino
                    • I Offline
                      iotmaker
                      you can find the code that is working right now for TTN US here on my GitHub
                      I also made a guide on my blog
