    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 112.5k Views 57 Watching
    • _ Offline
      _peter @danielm
      @danielm I have to deliver a LoRaWan sensor node within about 15 days giving me the chance to deep-sleep for 10 minutes and that when it wake up do not join again. is possible ?
      • I Offline
        irvinvp @bucknall
        @bucknall Thank you, we are waiting for the shields.
          bucknall @_peter
          @_peter If you're using a LoPy (Development Kit), you can currently get deep sleep with a Pytrack or Pysense - without these you'll need to wait until the Deep Sleep Sheild arrives
          Developer Evangelist - Pycom
          _ 1 Reply Last reply Reply Quote 0
          • _ Offline
            _peter @bucknall
            @bucknall I designed the board for Lopy and thought of replacing it with the oem expansion board + oem module. According to you is it possible?
              bucknall @_peter
              @_peter Yes, this is possible. The footprint of the board is slightly wider than the LoPy but the functionality and pinout is identical to that of the LoPy. This is can be used as an exact replacement for the LoPy!
              • RobTuDelftR Offline
                RobTuDelft
                Is the script for the PIC also somewhere available?
                Hackster | About me
                  mcook @Fred
                  @Fred
                  I received my PyTrack boards today. I have attached my LoPy to one of them. I am powering the PyTrack via USB. The USB is plugged into a USB multimeter. With the WiFi on, I see it is drawing about 125 mA at 5 VDC. After entering deep sleep, I see the current is reduced to ~48 mA. Is there some configuration that needs to be done in the code in order for the PyTrack boards to work properly with Deep Sleep?
                  Mike
                    @mcook, entering deepsleep using the Pytrack as the controller of the operation requires a different approach. We have a library for this that will be published in a few days this week. This library also allows to performing several different operations on the PIC microcontroller that's on the Pytrack/Pysense like reading the battery voltage.
                      In the meantime while we publish the official library later this week, here is a short version of it which can be used to enter deep sleep mode using the Pytrack/Pysense board and wakeup after a pre-defined number of seconds:
                      from machine import I2C
                      from machine import Pin
                      I2C_SLAVE_ADDR = const(8)    # This one seems to be an unpopular addresss
                      LIS2HH12_I2C_ADDR = const(30)   # both Pysense and Pytrack have the accelerometer onboard
                      CMD_PEEK = const(0x0)
                      CMD_POKE = const(0x01)
                      CMD_MAGIC = const(0x02)
                      CMD_HW_VER = const(0x10)
                      CMD_FW_VER = const(0x11)
                      CMD_PROD_ID = const(0x12)
                      CMD_SETUP_SLEEP = const(0x20)
                      CMD_GO_SLEEP = const(0x21)
                      CMD_BAUD_CHANGE = const(0x30)
                      CMD_DFU = const(0x31)
                      REG_CMD = const(0)
                      REG_ADDRL = const(1)
                      REG_ADDRH = const(2)
                      REG_AND = const(3)
                      REG_OR = const(4)
                      REG_XOR = const(5)
                      ANSELA_ADDR = const(0x18C)
                      ANSELB_ADDR = const(0x18D)
                      ANSELC_ADDR = const(0x18E)
                      ADCON0_ADDR = const(0x9D)
                      ADCON1_ADDR = const(0x9E)
                      _ADCON0_CHS_POSN = const(0x02)
                      _ADCON0_ADON_MASK = const(0x01)
                      _ADCON1_ADCS_POSN = const(0x04)
                      _ADCON0_GO_nDONE_MASK = const(0x02)
                      ADRESL_ADDR = const(0x09B)
                      ADRESH_ADDR = const(0x09C)
                      PORTC_ADDR = const(0x00E)
                      WPUA_ADDR = const(0x20C)
                      MEMORY_BANK_ADDR = const(0x620)
                      class Pysense:
                          def __init__(self, i2c=None, sda='P22', scl='P21'):
                              if i2c is not None:
                                  self.i2c = i2c
                                  self.i2c = I2C(0, mode=I2C.MASTER, pins=(sda, scl))
                              self.reg = bytearray(6)
                              scan_r = self.i2c.scan()
                              if not scan_r or LIS2HH12_I2C_ADDR not in scan_r or not I2C_SLAVE_ADDR in scan_r:
                                  raise Exception('Pysense board not detected')
                          def _write(self, data, wait=True):
                              self.i2c.writeto(I2C_SLAVE_ADDR, data)
                              if wait:
                                  self._wait()
                          def _read(self, size):
                              return self.i2c.readfrom(I2C_SLAVE_ADDR, size + 1)[1:(size + 1)]
                          def _wait(self):
                              time.sleep_us(100)
                              while self.i2c.readfrom(I2C_SLAVE_ADDR, 1)[0] != 0xFF:
                                  time.sleep_us(100)
                          def _send_cmd(self, cmd):
                              self._write(bytes([cmd]))
                          def setup_sleep(self, time_s):
                              self._write(bytes([CMD_SETUP_SLEEP, time_s & 0xFF, (time_s >> 8) & 0xFF, (time_s >> 16) & 0xFF]))
                          def go_to_sleep(self):
                              self._write(bytes([CMD_GO_SLEEP]), wait=False)
                              # kill the run pin
                              Pin('P3', mode=Pin.OUT, value=0)
                      Example usage:
                      from pysense import Pysense
                      py = Pysense()
                      py.setup_sleep(5)   # setup a 5 seconds sleep time
                      py.go_to_sleep()
                      This works for both Pysense and Pytrack.
                        lj Pybytes Beta @Fred
                        @Fred
                        I didn't received my Deep Sleep Shield , what is the process to check if my request has been registered, plan and hipped to me?
                        best
                        Luc
                        • I Offline
                          irvinvp @bucknall
                          @bucknall Did the shields arrive?
                            leogaggl
                            I am also wondering what the process is if the Deep Sleep Shields don't arrive. I ordered them when the email went around for my order of LoPy's but never received anything ?
                              rskoniec
                              I've filled the form at https://www.surveymonkey.co.uk/r/PSTPWBB (mid April) and still nothing - no email confirmation, order progress and no DS shields.
                              @Fred said in Root causes of high deep sleep current:
                              Dear All,
                              A quick update on this topic to confirm we are currently testing the Pilot Run samples in Eindhoven. All going well and we expect to have shields to ship circa 2 to 3 weeks e.g. 5/6 June. (...)
                              @Fred Any news?
                                We have received all the surveys filled up to now and everything is going OK. We are targeting mass production of the deep sleep shields in early July and ship shortly afterwards.
                                  crankshaft @Fred
                                  @Fred - Is it possible to acknowledge receipt of the request for a shield when it is initially made and then notify us when it is dispatched, as at the moment I have no idea whether my submission was successful, or when I am likely to receive the shields ?!
                                    athtest800
                                    Hi!
                                    The PIC10F322 needs programming? If yes, where can I find the code?
                                    Thank you!
                                    • I Offline
                                      irvinvp
                                      @bucknall Did the shields arrive? is 13th July and i don´t have news.
                                        rskoniec @irvinvp
                                        @irvinvp Here is the answer https://forum.pycom.io/topic/1480/deep-sleep-shields-delivery-update
                                          jalperin
                                          I wish to run my lopy on a pysense with the lowest possible current draw from a LiPo battery. I assume I would plug the deep sleep shield in between them. Correct?
                                          Could someone please summarize in one place all the appropriate actions to turn off everything but awake periodically to take a lux reading and transmit it via lora? Thanks for your help.
                                            jcaron @jalperin
                                            @jalperin from what I understood, the Pysense (and Pytrack) boards actually incorporate what is present on the deep sleep shields.
                                            However, there is still a lingering issue on the Pysense (not the Pytrack) which still uses more current than it should in deep sleep, still waiting for a solution for this.
                                            • 5
                                            • 6
                                            • 7
                                            • 3 / 7
