setsockopt fails with EOPNOTSUPP
When trying to run the LoRa ABP example code (from https://docs.pycom.io/pycom_esp32/library/network.LoRa.html#network.LoRa) on a LOPY, the following line:
fails with EOPNOTSUPP.
From the console, this happens:
Connecting to a Pycom device... Connected >>> s2=socket.socket(socket.AF_LORA,socket.SOCK_RAW) >>> s2.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) Traceback (most recent call last): File "<stdin>", line 1, in <module> OSError: [Errno 95] EOPNOTSUPP >>> os.uname() (sysname='LoPy', nodename='LoPy', release='1.6.7.b1', version='v1.8.6-493-g99ac80fe on 2017-03-03', machine='LoPy with ESP32', lorawan='1.0.0')
Any ideas?
@jmarcelino Thanks for the quick reply. Yes, I'm in US915, and setting it to 3 does solve the issue. Now to figure out how to view what I'm sending from the LoPy to the mLinux Conduit gateway... :-/
SO_DR (datarate) 5 is only available in LoRa 868Mhz (EU868). Are you in a different region? For US915 it should be 3.
I'm experiencing the same problem. Was there ever any resolution to this based on the OP?
Use spaces in your keys
Hi @bbfnq! Apologies, I've been travelling without access to a LoPy the last couple of days - I did try it on the weekend at a hackathon I was at and there didn't seem to be any problems - I'll have a go at it when I'm back at the office tomorrow!
@bucknall Hi - just wondered if you had had any success looking at this? Is there any more information I might provide to help?
Hi @bucknall
The code is exactly as in the example (except that the keys are different).
from network import LoRa import socket import binascii import struct # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN) # create an ABP authentication params dev_addr = struct.unpack(">l", binascii.unhexlify('26011769'.replace(' ','')))[0] nwk_swkey = binascii.unhexlify('E44A1E59045F3CDD81A2606491F626D1'.replace(' ','')) app_swkey = binascii.unhexlify('85FFDD197900F1AD6D86F3E7DD9F46FC'.replace(' ','')) # join a network using ABP (Activation By Personalization) lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey)) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) # make the socket non-blocking s.setblocking(False) # send some data s.send(bytes([0x01, 0x02, 0x03])) # get any data received... data = s.recv(64) print(data)
boot.py is:
from machine import UART import os uart = UART(0, 115200) os.dupterm(uart)
Running the code (either by resetting the PyCom, or by pressing the Run button in Pymakr) results in the following at the console:
Traceback (most recent call last): File "main.py", line 21, in <module> OSError: [Errno 95] EOPNOTSUPP
Also from the console:
We have 2 LoPy boards and the problem occurs with both.
Thanks.
Hi @bbfnq I'm trying to recreate what's happening with your code, are you running anything in your main.py script?
