    possibility to use Lora objenious network in France with Lopy ?
    franceobjeniouslopylora
    15 Posts 8 Posters 4.3k Views 9 Watching
    • PiAirP Offline
      PiAir
      Without having hands-on experience with the network, in theory: yes. The objenious network uses LoRa, you probably just need an account and an online environment to create the correct keys (similar like you do with TTN) to add in the configuration of the LoPy.
      If I want to switch my LoPy from TTN to the Dutch commercial KPN network, it literally is just a matter of changing the AppSKey, the Device address and the Device EUI in the config.py file and resetting the node.
      I looks like someone has been experimenting with the LoPy on objenious and had some problems specific to the network. See this post. Maybe he can give (you) an update on how stable the network is now?
      (and then you can post it here again so others can find that info more easily also)
        raxy
        i also leave in paris and want to connect my pycom to objenious infrastructure; i have a company account there,
        for now , i cannot even be seen by their spot admin web interface trying to join their network, i do not know why yet
        Jurassic PorkJ 1 Reply Last reply Reply Quote 0
        • Jurassic PorkJ Offline
          Jurassic Pork @raxy
          hello raxy ,
          here is the answer of objenious for my request :
          Nous sommes en train de mettre en place des accords avec Pycom pour ajouter la connectivité Objenious avec les modules Pycom.
          Je vous invite à recontacter Pycom pour bénéficier de la connectivité en plus des modules.
          Bien cordialement,
          Guillaume TRANIER | Chef de projet partenariat
          20 rue Troyon, 92310 Sèvres | gtranier@objenious.com
          but no news of those agreements from pycom.
            jmarcelino @Jurassic Pork
            @Jurassic-Pork
            Sounds like those guys don’t understand the whole point of LoRa is you shouldn’t need agreements to connect any - LoRa compatible and especially certified - device to a network.
            Just my opinion but I’d be scared about putting my business on such a network, thry’ll just get in the way at every corner.
              raxy
              the lopy came from objenious and they said it should work on their network; they just recommended to flash the latest firmware (for doing class C);
              they are in the process of delivering me all the keys to use upon join; for now , the lopy pretends to be another device (already fully registered and working but powered off)
                jellium
                Has any of us managed to connect a LoPy to the Objenious LoRaWAN network?
                I can't.
                With the example LoRaWAN OTAA join method code, using proper app EUI and app key doesn't allow me to join the network. Besides, there is no event raised when the handshake is made, how would you debug the join failure? I have tried my own approach to join, tuning parameters such as bandwith, coding rate and spreading factor, nothing seems to do the trick.
                Any idea?
                  raxy
                  guys,
                  with the help of Nicolas C. from objenious,
                  I can now join their network with my LopY , both in class A and.... in class C!
                  I can do uplinks and get asynchronous downlinks using a callbac in class C and in micropython.
                  I'll share how I did that, if anyone is interested
                  J G 2 Replies Last reply Reply Quote 0
                    jellium @raxy
                    @raxy I am very interested, please share (-;
                      raxy
                      ok here is the code...
                      #-- lora1.py, test of objenious uplink / downlink
                      # by raxy asOf 20jun17 : works OK in class C!
                      from network import LoRa
                      import binascii
                      import struct
                      def lora_cb(lora):
                          global s
                          events = lora.events()
                          if events & LoRa.RX_PACKET_EVENT:
                              data = s.recv(64) # will return immediately w/ or w/o data
                              print("<<",data)
                      # create an OTAA authentication parameters
                      app_eui = binascii.unhexlify('xxx')
                      lora = LoRa(mode=LoRa.LORAWAN, adr=True, device_class=LoRa.CLASS_A)
                      #your Class A keys
                      dev_eui = binascii.unhexlify('yyy'.replace(' ','')) #classe A
                      app_key = binascii.unhexlify('zzz'.replace(' ','')) #classe A
                      # xor Initialize LoRa in LORAWAN mode.
                      lora = LoRa(mode=LoRa.LORAWAN, device_class=LoRa.CLASS_C, adr=True)
                      #your Class C keys
                      dev_eui = binascii.unhexlify('xxx') #classe C
                      app_key = binascii.unhexlify('yyy') #classe C
                      print('dev_eui==',dev_eui)
                      # join a network using OTAA (mandatory on objenious WAN)
                      while not lora.has_joined():
                          print('joining..')
                          time.sleep(3.0)
                      print('connected to Objenious LoRaWAN!')
                      # create a LoRa socket
                      # set the LoRaWAN data rate
                      lora.callback(trigger=(LoRa.RX_PACKET_EVENT), handler=lora_cb)
                      # loop for class C
                      # make socket non-blocking
                      s.setblocking(False)
                      print('waiting...')
                          time.sleep(1.5)
                      # loop for class A
                      # make the socket blocking
                          s.setblocking(True)
                      # send some data
                          print('sending data')
                          data = s.recv(64)
                          print("<<",data)
                          time.sleep(15)
                        gas @raxy
                        @raxy I'm interested too Thank Nicolas C,
                        if you can share
                        J R 2 Replies Last reply Reply Quote 0
                          jellium @gas
                          @gas Have you tried the code raxy posted?
                          I did (with some rearrangements) and it works. I suppose what is important is to specify adr and device_class when defining the LoRa object. Also, when calling the join method, I had not specified dev_eui in the auth parameter which can be (but it should not matter very much).
                          Thanks @raxy by the way (-;
                          It's quite off topic but now I have to figure out how to properly use machine.deepsleep() along with LoRaWAN. As waking up from deep sleep resets the board, one has to re-join the LoRaWAN network after every deep sleep interval... Unless there is a way to "keep" the LoRaWAN session active despite a board reset?
                            raxy @gas
                            @gas email contact@objenious.com , then ask for Nicolas Carvallo.
                              stef @raxy
                              Hi all ,
                              trying to connect to objenious network ( thanks raxy code )
                              i 've got a invalidMIC error on join .
                              Is it linked to the keys ? ( i use their XLS template to import the sensor)
                              What sensor type did you use for the LoPy ? ( as pycom not in the sensor list )
                              Thank's in advance.
                              Stephane A.
                              • E Offline
                                Emmanuel Goudot @stef
                                @stef , sensor type Pycon should be avail:
                                0_1504110986341_upload-1a444523-8dc6-46da-9fee-46a782b7b215
