    Wipy 2.0 PinOut, Alternate Functions
    12 Posts 4 Posters 3.1k Views 4 Watching
      joaquin
      uhashlib have only md5, sha256 will be added?
      But update in md5 does not update the disgest, coudl be corrected, please
        Ralph
        Yes, the sha256 will be added in a future release.
        Can you provide an example of how you are using the md5 in this case? Note that in the docs for uhashlib, it states that after you call .digest(), no more data can be fed into the hash.
        If this doesn't solve it, please make a new post for this issue, so other people with the same issue can find it on the forum.
          joaquin @Ralph
          @Ralph
          This is way used, made the same on Linux with 3.5 and works fine:
          Res1=md5(var1)
          Res1.update (var2)
          Res1.digest ()
          Is Correct?
          Another question is about RTC, not found, is it Ready?
            Ralph
            @joaquin It's a bit off topic, but yes that should work. You do need to use hexlify to convert it though. For completeness, this is my test script that worked:
            import uhashlib
            import binascii
            res1 = uhashlib.md5("foo")
            res1.update("bar")
            binascii.hexlify(res1.digest())
            >> b'3858f62230ac3c915f300c664312c63f'
            RTC is not ready yet, but it will probable be there in the next release
              joaquin
              Ralph,
              Good thanks.
                livius
                this one is not good?
                0_1478245153715_upload-e9ec1030-9dad-4835-8146-f755a625a5e7
                  littlebat @livius
                  @livius said in Wipy 2.0 PinOut, Alternate Functions:
                  That is for wipy 1.0 not wipy 2.0
                    livius
                    And it was changed totally? Or some minor changes?
                    I suppose only some minor changes..
                      littlebat @livius
                      Wipy 2.0 uses completely different chip than wipy 1.0 so yes totally new.
                        livius
                        I didn't know that chip was changed. Thank you for the info.
