Type error in Service Routine
I randomly get the following error:
Unhandled exception in callback handler TypeError: 'bytearray' object is not callableor
Unhandled exception in callback handler TypeError: 'slice' object is not callableThis happens in a callback which is triggerd by a pin interrupt. Defined like so:
int_pin.callback(trigger=Pin.IRQ_RISING, handler=self.handler)The callback function is a very simple method of an object:
def handler(self, arg): self.todo = TrueActually, there is no such type as
sliceorbytearrayinvolved in the callback which makes me think its a bug ...Sometimes the callback works fine for several thousands of times, some times for just a few hundreds.
After that exception the callback seems to be never called again, even tough it should have been called again.I have a main loop which looks as follows and shall handle the todos:
while True: irq = machine.disable_irq() if this.todo: this.todo = False do_this() if that.todo: that.todo = False do_that() machine.enable_irq(irq) time.sleep_us(1)Any ideas?
Oh yea, forgot to mention:
(sysname='LoPy', nodename='LoPy', release='1.6.12.b1', version='v1.8.6-593-g8e4ed0fa on 2017-04-12', machine='LoPy with ESP32', lorawan='1.0.0')
