    Does deepsleep work at all
    deepsleep
    83 Posts 20 Posters 50.6k Views 23 Watching
    • R Offline
      Robin @daniel
      @daniel Seems to work for me too now.
      Adding the garbage collector statements in the calling code seems to be crucial through.
        johncaipa @daniel
        @daniel I'm testing the deepsleep example but I get the following errors:
        File "main.py", line 7, in <module>
        File "/flash/lib/deepsleep.py", line 143, in get_wake_status
        File "/flash/lib/deepsleep.py", line 76, in peek
        IndexError: bytes index out of range
        I am doing something wrong?
        thanks
          tmz @johncaipa
          @johncaipa
          Try the latest - https://github.com/pycom/pycom-libraries/blob/master/deepsleep/deepsleep.py
          J A 2 Replies Last reply Reply Quote 0
            johncaipa @tmz
            @tmz that is the library I'm using, and which errors are generated
              Arnaud @tmz
              @tmz said in Does deepsleep work at all:
              Just tried the deepsleep example on Sipy 1.0 - Pytrack 1.0 with latest deepsleep.py and after firmware upgrade to 1.7.9b3 and got the same error than John.
              I understood that Pytrack serves as deepsleep shield.
              All this deepsleep troubles merged with lack of documentation is really frustrating...
                daniel
                @Arnaud with pytrack or pysense simply use their own libraries which also provide the deepsleep functionality:
                https://github.com/pycom/pycom-libraries/tree/master/pytrack
                  Arnaud @Arnaud
                  Nice to hear that! Please help us with a bit more explicit documentation. You might be aware of this now based on the comments, you're building up hours of frustration which is not was intended at first I'm sure with the beautiful specs of your products.
                  BTW, I think deepsleep example lacks an import deepsleep for constants.
                    Arnaud @daniel
                    @daniel I've tried the latest pytrack lib for deepsleep with very simple main.py:
                    from pytrack import Pytrack
                    print( "Waking up")
                    Some job
                    print( "Going to sleep")
                    pytrack = Pytrack()
                    pytrack.setup_sleep( 10 )
                    pytrack.go_to_sleep()
                    Waking up with a buton press works.
                    Board never wakes up on timer.
                      jcaron
                      Just to make sure, you have the latest firmware (0.0.4 I believe) on the Pytrack? You can check with pytrack.read_fw_version().
                        Arnaud @jcaron
                        @jcaron read_fw_version returns 2.
                        Since I haven't done any pytrack firmware upgrades since June, I'll assume I have to.
                        This might be a hint for improving docs:
                        Required Pytrack Firmware: x.y.z
                          Arnaud @Arnaud
                          @jcaron
                          I have updated the pytrack firmware to 0.0.4 with DFU-util (Mac OSX).
                          From there:
                          The hearbeat (blue led) is not active anymore.
                          I have a lot of troubles gettting a console connection to the board.
                          Sometimes, the board executes main.py, prints a few lines but hangs on while printing firmware version and connection is lost.
                            jmarcelino @Arnaud
                            @Arnaud
                            Can you try another USB cable?
                              daniel
                              @Arnaud, I think the firmware upgrade failed. Just tried it again using the DFU procedure.
                              Cheers,
                              Daniel
                                Arnaud @daniel
                                @daniel Got this during Pytrack firmware upgrade:
                                Match vendor ID from file: 04d8
                                Match product ID from file: f014
                                Deducing device DFU version from functional descriptor length
                                Opening DFU capable USB device...
                                ID 04d8:f014
                                Run-time device DFU version 0100
                                Claiming USB DFU Runtime Interface...
                                Determining device status: state = dfuIDLE, status = 0
                                dfu-util: WARNING: Runtime device already in DFU state ?!?
                                Claiming USB DFU Interface...
                                Setting Alternate Setting #0 ...
                                dfuIDLE, continuing
                                DFU mode device DFU version 0100
                                Device returned transfer size 64
                                Copying data from PC to DFU device
                                Download [=========================] 100% 16384 bytes
                                Download done.
                                state(2) = dfuIDLE, status(0) = No error condition is present
                                Done!
                                  Arnaud @jmarcelino
                                  @jmarcelino @daniel
                                  Solved.
                                  For the sake of it, I've tried with another USB cable among other stuff. The only thing I did not do is reboot the internet...
                                  Sipy: upgraded firmware to the brand new 1.8.0b1
                                  Pytrack: re-upgraded firmware to 0.0.4
                                  Pymakr in Atom: checked latest version 1.1.0
                                  Still no heartbeat.
                                  Sometimes I got a connection to the board (after multiple connect clicks).
                                  Main.py was then running with weirdo character when printing pytrack firmware version (instead of 4), followed by deepsleep command.
                                  Console connection was immediately lost right after.
                                  After a safe boot with latest firmware (1-3 sec), I managed to get a console prompt and reset the code part. Everything is back to normal, will get back to testing the deepsleep.
                                    Arnaud @Arnaud
                                    @daniel @jmarcelino
                                    Ok back to testing, I got the point (It actually took a long time to get deep into my brain!) Once the board in deepsleep mode, there is little chance I could get a console connection to it...
                                      colin.guyon @daniel
                                      @daniel Hello, do you know if a solution is going to be raised about the deep sleep high current (520 uA at 5v instead of few uA that were announced) ? Thanks
                                        daniel
                                        @colin-guyon yes we will sort it out, we just need need a few more days to crack it as other things have delayed us.
                                        • R Offline
                                          Robin @colin.guyon
                                          @daniel i am still waiting on a solution to the 520 uA instead of <25uA problem for
                                          • the deep sleep shield
                                          • on a LoPy
                                          • attached to a LiPo battery
                                          We are about to put 10 LoPy's into the wild to fend for themselves and report back with tales of great adventures.....but the current is still killing the battery.
                                          A month ago you mentioned you guys were working on it. When can we expect a solution?
                                          @colin-guyon said in Does deepsleep work at all:
                                          robert-hhR I 2 Replies Last reply Reply Quote 0
                                            robert-hh @Robin
                                            @robin Even if 520µA is large compared to 25µA, it's not that bad. A typical 18650 LiPo cell can serve that for 8 months (3000 mAh/0.52mA = 5769h or ~240 days). Once you're sure that besides the battery your set-up will run for that period, the battery becomes an issue. And the more frequent your device communicates, the less important is the standby current.
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 4 / 5
