    Console output messed up using Pymkr plugin "Run"
    consolethread
    9 Posts 3 Posters 2.7k Views 3 Watching
      Andrea Filippini
      Hi all, I'm using a few threads in my script but I have a problem with the console. The first thread that I start is used to manage the WiFi connection as described in the tutorials like this:
      [REMOVED AS OF EDIT2]
      The problem is that at first boot (at power up) I only get this thread's output. Any other "print" gets lost.
      The only way to be able to see the output is to stop and restart the script (i'm using Atom plugin) so the WiFi stays connected an the output is brief.
      How can I solve this? I'm facing serious problems developing
      EDIT:
      Thanks to @Innocenzo I can say for sure that the issue is with the Pymkr plugin for Atom. If I use "execfile('main.py')" all the output is printed (even inside the Atom console); this means that there's a bug in the "Run" command
      EDIT 2:
      Use this code to reproduce the problem (change wifi credential to a valid one). Using the "Run" command the output stops after successfully connecting to the WiFi network.
      If you use "execfile()" the output keeps being printed
      import _thread
      from network import WLAN
      def th_wifi_mng(delay):
          try:
              wlan = WLAN()
              found = 0
                  if not wlan.isconnected():
                      nets = wlan.scan()
                      for net in nets:
                          if net.ssid == "yourSSID":
                              wlan.connect(net.ssid, auth=(net.sec,"yourPsw"), timeout=5000)
                              found = 1
                      if found == 1:
                          while not wlan.isconnected():
                  wifi_connected = wlan.isconnected()
                  time.sleep(delay)
          except Exception as e:
              print('th_wifi_mng', e)
      # WiFi initialization
      wlan = WLAN()
      if(wlan.mode() != WLAN.STA):
          wlan = WLAN(mode=WLAN.STA)
      # spawn threads
      _thread.start_new_thread(th_wifi_mng, (2,))
          print("main loop")
          time.sleep(.1)
      I 1 Reply Last reply Reply Quote 1
      • I Offline
        Innocenzo @Andrea Filippini
        @Andrea-Filippini Try to execute your code on Terminal like Tera Term or Termite. Sometimes the Atom plugins does not print me everything.
          Andrea Filippini @Innocenzo
          @Innocenzo I can connect to the REPL console via USB cable, but I don't exactly know how to run a python script from there :/
          • I Offline
            @Andrea-Filippini Use Filezilla or ampy to put your script on board. After, from REPL, use
            execfile("myscript.py")
            • R Offline
              Ralph
              hi @Andrea-Filippini can you post your code, or a simplified version of it, so I can try to replicate the problem? The quick usage example from the docs seems to be working for me.
                Andrea Filippini @Ralph
                @Ralph See edit 2
                • R Offline
                  Ralph @Andrea Filippini
                  @Andrea-Filippini Thanks for posting your code. Using it I got the same issue and found the bug that was causing it. It's been solved in the latest commit on the develop branch on github. It'll be included in the next release. Until then, feel free to manually install the plugin from the develop branch
                  A 2 Replies Last reply Reply Quote 0
                    @Ralph Thank you! I confirm the bug is fixed
                      @Ralph It seems there's a new bug. (almost) Every time I click the "Sync" button all the files get uploaded. Also I notice something that looks like a piece of checksum being printed like this:
                      >>> Syncing project (main folder)...
                      >>> [1/12] Writing file communication.py
                      c8474829a403c5fefb5e339b"]]
                      [2/12] Writing file config.py
                      [3/12] Writing file globals.py
                         [...etc...]
                      [12/12] Writing file utils.py
                      Synchronizing done, resetting board...
                      EDIT:
                      Also, "Run" command on a file doesn't update the file on the flash, resulting in a strange behaviour if the current file is also present in the flash.
                      Editing the script and running it seems to use the classes from the file on the flash memory, and the "top level" instructions from the editor file :/
                      EDIT2:
                      Now the "Sync" end with an error. I rebooted the board, the PC and updated the firmware....
                      >>> [1/13] Writing file communication.py
                      [2/13] Writing file config.py
                      Synchronizing failed: Write failed. Please reboot your device manually.
                      EDIT3:
                      Fixed with the new release
