    How to use the nano gateway also as a node?
    lopyhardwarewatchdog
    1 Posts 1 Posters 892 Views 1 Watching
    • lollisoftL Offline
      lollisoft
      while I am trying to get a stable running nano gateway, also tried to monitor the memory usage by sending them with the stat message (an extra field).
      Is this possible or is there any solution, for example starting a thread and within that thread, the node code is placed.
      Also I would be interested in any hardware watchdog over the blinking blue LED. If that LED stops blinking, the hardware watchdog timer should reset the board.
