    Check if file or directory exist
    lopy
    3 Posts 3 Posters 1.2k Views 3 Watching
      assia
      How can i check if file or directory exist as /sd for example? It does not work with :
      os.path.isfile(filename)
      • RobTuDelftR Offline
        RobTuDelft
        Try os.stat(path) or os.listdir([dir])
        Without data you're just another person with an opinion.
        Hackster | About me
          Andrea Filippini
          The most pythonish way is to assume that the file file or directory exists. A simple approach could be:
          try:
              os.stat(filename)
              #if here file or dir exists
          except:
              #if here file or dir does not exist
