    LoPy + GPS receiver on The Things Networks
    Scheduled Pinned Locked Moved Projects
    gpslopyuart
    9 Posts 3 Posters 4.9k Views 3 Watching
    • PiAirP Offline
      PiAir
      If you have a LoPy node that is moving around, knowing where it is, can be very useful. Think containers or cars moving around. GPS receivers can be expensive or very cheap. I used a cheap one from China to connect to the LoPy.
      Like before I shared the code online and created a write-up on my blog.
      I hope it is useful to others also.
      p.s. Alex will be doing a live broadcast about the Pytrack and GPS this week. It's a bit more expensive, but also has a 3 axis 12-bit accelerometer and combines everything in a neat small package.
      (fixed the link to the github repository, thanks Rob!)
      L 2 Replies Last reply Reply Quote 0
        livius @PiAir
        @PiAir
        Thanks for the link on aliexpress for NEO6MV2
        Is this real link to seller or you buy it from different place?
        I buy it normally for 60% higher price in my country.
        J PiAirP 2 Replies Last reply Reply Quote 0
          jmarcelino @livius
          @livius
          there are often recycled modules, you can even get a similar board for $3.78 ( inc free shipping, at least to UK) https://www.aliexpress.com/item/GY-NEO6MV2-NEO-6M-GPS-Module-NEO6MV2-with-Flight-Control-EEPROM-MWC-APM2-5-large-antenna/32654502054.html
          • PiAirP Offline
            PiAir @livius
            @livius This was the link to the actual reseller that I bought it from. The one that Jose links to is indeed even cheaper, but the text "Attention: the chip is old" kind of puts me off on that one. :) (although they just mean the chip has been used)
            Would I buy them if I was building a sensor network for a big company? Probably not. For small projects like this, for me they are cheap enough to take the chance.
              livius @jmarcelino
              @jmarcelino @PiAir
              I am only asking if someone buy something from aliexpress and this work ;-)
              I know that we can buy it even cheaper.
              But i bookmark any link with working models which someone buy from china.
              Sometimes whole module parts toogether have bigger priority then "quality".
              But i always try to minimize risk then.
                jmarcelino @livius
                @livius
                I think you can safely buy from Aliexpress, it's easy to make a claim if something doesn't work and sellers are usually OK with refunding. I never had any problems there and I spend quite a bit!
                Should we start a "Bargains" thread here with "companion" stuff like ADCs, sensors, tools, components like there is in the TTN forums? I personally have a list about 100+ favourite Ali sellers and an even longer one with interesting products :-)
                PiAirP L 2 Replies Last reply Reply Quote 1
                • PiAirP Offline
                  PiAir @jmarcelino
                  @jmarcelino Don't know if there is a need to duplicate that TTN thread. Maybe just link to it? :)
                  I also never had any real problems with sellers, sometimes it takes a while, one or two refunds requested (and received) so far after (too) many orders.
                    livius @PiAir
                    @PiAir
                    I use near to always same gps model and it is quite accurate
                    but not always. Have someone other gps more accurate in near price
                    sample
                    0_1495132725203_upload-e084e220-cc8f-41bd-92ed-726726525e75
                    this is data from 5 hour testing gps on the window. I am in yellow point and not moving.
                    UPDATE
                    This is only area - but 94% points are really near to yellow point
                      livius @jmarcelino
                      @jmarcelino
                      I think that we can create something more accurate - on that link all is mixed up
                      Adding not one topic only new menu group e.g.:
                      ->Where to buy:
                      --------->Sensors
                      ------------------>I2C
                      ------------------>analog
                      --------->switches
                      --------->Bateries
                      --------->antennas
                      --------->simple electronics
                      --------->box
                      or only limit it to interesting sensors.
                      But as always on such topic we can end with spam with adverts
                      not real used items by users :(
