Import a library and all its dependencies on lib folder
Hi ,
I would like to use queues to communicate between my threads with this library : https://pypi.python.org/pypi/micropython-uasyncio.queues/0.1.2
However, this library need
collections.dequeanduasynio.core.1 from collections.deque import deque 2 from uasyncio.core import sleepI went to the micropython-lib github repository, I downloaded
collection.dequeand paste the source file into the lib folder.I think I'm not importing libraries correctly because I need to modify the line
from collections.deque import dequetofrom collections import dequeI tried to do the same thing with the
uasyncio.coremodule but it also needs theloggingmodule.I thing it should have a way to install a module and all its dependencies at the same time right?
I can't imagine the only way is to manually import all the dependencies.Thank you in advance.
@Arkaik
do you havelogging.pyin your lib folder? -
Hi @livius, no I don't have it in the lib folder.
I could put it in this folder but I imagine a situation where the module logging (or another one, whatever) also needs dependencies, I'll need to dowload them too.
And if its dependencies also need other dependencies it will be a pain in the *** to import all of them independently, even more if I need to modify the way they are imported.
That's why I'm asking if there is a faster/easier way to import a module and all its dependencies?
@Arkaik
Downloading whole repository?
How do you imagine that it will be automagically?
I know that this is not the same but:
Same with web page - you save it and it have link to other site. If it will automatically download all linked pages and all linked pages linked in linked pages - you will be attempting to download whole internet ;-) -
@livius
Hi thought an apt-get like or pip-like system would exist ^^.I know that when I use pip for installing new modules there is a requires.txt file to download all the needed dependencies.
When I download the module on pypi.python the folder architecture is the following one:
micropython-uasyncio.core-1.0/ micropython_uasyncio.core.egg-info/ PKG-INFO requires.txt uasyncio/ core.py test.py test2.pySo because of this architecture I thought there would have a way to use the requires.txt file to recover all the dependencies.
Maybe I'm dreaming ^^If it doesn't exist it's not a big deal, I'll just use the classic way ;-)
@Arkaik
classic way always work ;-)
