    Beacon scan give strange result with LoPy
    beaconlopyrssi
    2 Posts 2 Posters 1.3k Views 2 Watching
      stef
      Hi all ,
      I'm using the Lopy to scan Ibeacons , but i got very strange result:
      (got 5 beacons )
      I use Beacon from Kontackt ( based on nRF51822 )
      when 2 beacons in range of Lopy , Got to scan up to 20secondes for getting the second one appear
      So when scan time is fixed to 2secondes ( short time for battery save ) , lot of miss occur , RSSI value fluctuate from -50 to -90 from two scan ....
      And more than that , after 200-250 scan , Lopy stop reporting BT , must be hard reset to get it back....
      Read somewhere that is a ESP32 problems : BLE does not scan iBeacons
      Some of you have success with beacon scan with Lopy ? ( a brand to sugest ? )
      papasmurphP 1 Reply Last reply Reply Quote 0
      • papasmurphP Offline
        papasmurph @stef
        @stef I've reported the same problems, but in my case I scan continuously, as the LoPy is USB-powered. https://forum.pycom.io/topic/1255/lopy-stops-detecting-ble-advertisements I very much hope it's not a hardware problem.
