[SOLVED] import json: AttributeError: 'module' object has no attribute 'VERBOSE'
  • Pybytes Beta
    Using uPython's json library and the latest WiPy 2.0 firmware.
    Edit: Didn't realize there's a built in ujson. Will use that instead.
    >>> import json
      File "/flash/lib/json/__init__.py", line 110, in <module>
      File "/flash/lib/json/decoder.py", line 6, in <module>
      File "/flash/lib/json/scanner.py", line 13, in <module>
