Two Lopy communicate via BLE, LOSE connection, CANNOT read service.
Hello, I am trying communicate two lopy use BLE, one is server, another is client.
The server success advertising and client could notice and connect. But we I am trying to for loop the service, it goes wrong and of course, I cannot read the characteristic.Here is the server code.
from network import Bluetooth bluetooth = Bluetooth() bluetooth.init() #config data before send bluetooth.set_advertisement(name='LoPy', manufacturer_data = 'lopy_server_1', service_data = b'19950922' ,service_uuid=b'1000000010000000') #bluetooth.set_advertisement(name='LoPy', service_data = b'19950922' , service_uuid=b'1234567890123456') def conn_cb (bt_o): events = bt_o.events() # this method returns the flags and clears the internal registry if events & Bluetooth.CLIENT_CONNECTED: print("Client connected") #not sure bt_o.advertise(False) elif events & Bluetooth.CLIENT_DISCONNECTED: print("Client disconnected") #not sure bt_o.advertise(True) bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) #start advertise bluetooth.advertise(True) #Create a new service on the internal GATT server. Returns a object of type BluetoothServerService. #bluetooth.service(uuid, *, isprimary=True, nbr_chars=1, start=True) # start = True service start immediately srv1 = bluetooth.service(uuid=b'1000000010000000', isprimary=True, nbr_chars=1, start = True) chr1 = srv1.characteristic(uuid = b'ab34567890123456', properties = Bluetooth.PROP_READ, value=99999, permissions = (1 << 0) | (1 << 4)) #property = Bluetooth.PROP_READ | Bluetooth.PROP_WRITE char1_read_counter = 0 def char1_cb_handler(chr): global char1_read_counter char1_read_counter += 1 events = chr.events() if events & Bluetooth.CHAR_WRITE_EVENT: print("Write request with value = {}".format(chr.value())) else: print('Read request on char 1') char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char1_cb_handler) #char1_cb = chr1.callback(trigger=Bluetooth.CHAR_NOTIFY_EVENT, handler=char1_cb_handler)Here is the client code
from network import Bluetooth import time bt = Bluetooth() bt.start_scan(-1) while True: adv = bt.get_adv() # resolve_adv_data(data , datatype) #bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'Heart Rate' # if adv and bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy': if adv and bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy': # stop scan before connect bt.stop_scan() print('333') try: connection = bt.connect(adv.mac) if(connection.isconnected()): print("Connection opened!") # a list of services services = connection.services() print('555') time.sleep(0.050) for service in services: print('444') time.sleep(0.050) print('Reading chars from service = {}'.format(service.uuid())) chars = service.characteristics() for char in chars: print('char {} value = {}'.format(char.uuid(), char.read())) connection.disconnect() break except: print("Error while connecting or reading from the BLE device") break else: time.sleep(0.050)I already add stop scan, but
connection.isconnected()never work.
I also try to moveconnection.isconnected()but after connect, the service never show.
