    Lora-Mac=‎FFFFFFFFFFFFFFFF
    lopymac
    26 Posts 11 Posters 12.3k Views 13 Watching
      Camot
      I am not sure how I can fix this....I have already tried a factory reset
      from network import LoRa
      import binascii
      print(binascii.hexlify(lora.mac()).upper().decode('utf-8'))
      Gives me : FFFFFFFFFFFFFFFF
      When I try to connect to The Things Network, my gateway shows the following dev eui (lora-mac) in the ttn console
      ‎12‎:‎47‎:‎55 868.3 4/5 SF9 BW125 205.8 app eui:70B3D57EF0004E35 dev eui:FFFFFFFFFFFFFFFF payload size:23 bytes
      • B Offline
        bucknall
        Hi @Camot,
        Have you used the firmware update tool to update your device? It seems like you might be running an outdated version of the firmware!
        Thanks!
        Alex
        Developer Evangelist - Pycom
          Camot @bucknall
          @bucknall said in Lora-Mac=‎FFFFFFFFFFFFFFFF:
          Hi @Camot,
          Thanks!
          Alex
          I have updated the Lopy with the firmware update tool yesterday.
          sysname='LoPy', nodename='LoPy', release='1.6.13.b1', version='v1.8.6-607-g9c8a0e9e on 2017-05-01', machine='LoPy with
          ESP32', lorawan='1.0.0')
          The good News is that I can enter that FFFFF... and use it like a regular address at the TTN config and it works as expected
          • B Offline
            bucknall @Camot
            @Camot What happens now if you run the command
              Camot @bucknall
              b'ffffffffffffffff'
                Camot @Camot
                @Camot said in Lora-Mac=‎FFFFFFFFFFFFFFFF:
                b'ffffffffffffffff'
                Any news? My Lopy still have this invalid Lora-MAC
                • B Offline
                  bucknall
                  Hi @Camot, I've checked with Daniel and he asked me to verify if you used the ESP-IDF tool to erase the flash on your device?
                  Try performing another firmware update and it should correctly write over the flash with our firmware and correct the LoRa MAC address.
                  Thanks for your patience!
                  C 2 Replies Last reply Reply Quote 0
                    daniel
                    Hello @Camot,
                    Did your LoPy was ever flashed with a custom firmware using the IDF? Did you perform a bulk erase on the flash memory?
                    Cheers,
                    Daniel
                      Camot @bucknall
                      I made another Firmware update but the MAC address is still FFFFFFFFFFFFFFFF
                        Camot @bucknall
                        @bucknall @daniel
                        any News?
                          cinezaster
                          @bucknall Still having this issue.
                          I upgraded firmware LoPy to '1.7.9.b3'.
                          PyTrack firmware is v0.0.4
                          LoPy Model: LoPy1.0r
                          • bmarkusB Offline
                            bmarkus
                            Try:
                            print(binascii.hexlify(lora.mac()))
                              cinezaster @bmarkus
                              @bmarkus unfortunately that doesn't work either. I already tried this.
                              Also when I look at the output of lora.mac() it returns b'\xff\xff\xff\xff\xff\xff\xff\xff' so one could only expect the id to be FFFFFFFFFFFFFFFF.
                              • E Offline
                                emerout
                                I have the same problem, address returned by lora.mac() is still FFFFFFFFFFFFFFFF.
                                History :
                                First time I played with Lopy, I have a different and right mac address.
                                Then I try to use a custom firmware, flash it, with no success (other story with external lib)
                                I came back to official firmware LoPy_868-1.7.6.b1.
                                And know it is stuck with this ffff... mac.
                                Any help appreciated !
                                  robert-hh @emerout
                                  @emerout Did you try to erase the flash with esptool.py?
                                  C E 2 Replies Last reply Reply Quote 0
                                    cinezaster @robert-hh
                                    @robert-hh I did try it to erase the flash.
                                    • E Offline
                                      emerout @robert-hh
                                      @robert-hh said in Lora-Mac=‎FFFFFFFFFFFFFFFF:
                                      I have performed :
                                      $ bin/esptool.py --port /dev/tty.usbserial erase_flash
                                      and then :
                                      $ bin/updater.py -t Downloads/LoPy_868-1.7.8.b1.tar.gz -p /dev/tty.usbserial -s 921600 flash
                                      re-uploaded my program,
                                      No success, mac is still FFFF...
                                      • E Offline
                                        emerout
                                        Is it possible to set lora device address programmatically when operate in OTAA mode ?
                                          robert-hh @emerout
                                          @emerout Did you check between erase & reflash, whether the device was erased? For instance by trying to run it.
                                          • E Offline
                                            emerout @robert-hh
                                            @robert-hh Yes, after erase there wasn't any python >>> prompt.
                                            Then after flashing firmware, my boot.py and main.py was gone.
                                            • 1
                                            • 2
                                            • 1 / 2
