    FSK and RX2 Windows
    fskrx2addchannel
    1 Posts 1 Posters 804 Views 2 Watching
      jubbs
      Hi have a channel plan that I need to match in the 868 spectrum and I am a bit confused about how to set the FSK and RX2 channels. Below is the Channel plan that I need to match and the channels that I have setup. Does anyone have any advice?
      Jubbs
      Channel Frequency (MHz) Bandwidth (kHz) Sp Factor / Data Rate
      0 864.8625 125 12-7 / 0-5
      1 865.0625 125 12-7 / 0-5
      2 865.4025 125 12-7 / 0-5
      3 865.6025 125 12-7 / 0-5
      4 865.9850 125 12-7 / 0-5
      5 866.2000 125 12-7 / 0-5
      6 866.4000 125 12-7 / 0-5
      7 866.6000 125 12-7 / 0-5
      LoRa 865.0625 250 7 / 6
      FSK 865.0625 125 50 kbps
      RX2 window: 866.5500 MHz, DR4 (SF8)
      Max power: 36 dBm
      Coding rate: 4/5
      def __init__(self, dev_addr, nwk_swkey,  app_swkey):
          lora = LoRa(mode=LoRa.LORAWAN, adr=True, public=True, tx_retries=3, tx_power=14)
          lora.add_channel(0, frequency=864862500, dr_min=0, dr_max=5)
          lora.add_channel(1, frequency=865062500, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=865402500, dr_min=0, dr_max=5)
          lora.add_channel(3, frequency=865602500, dr_min=0, dr_max=5)
          lora.add_channel(4, frequency=865985000, dr_min=0, dr_max=5)
          lora.add_channel(5, frequency=866200000, dr_min=0, dr_max=5)
          lora.add_channel(6, frequency=866400000, dr_min=0, dr_max=5)
          lora.add_channel(7, frequency=866600000, dr_min=0, dr_max=5)
          lora.add_channel(8, frequency=865062500, dr_min=6, dr_max=6)
          lora.remove_channel(9)
          lora.remove_channel(10)
          lora.remove_channel(11)
          lora.remove_channel(12)
          lora.remove_channel(13)
          lora.remove_channel(14)
          lora.remove_channel(15)
          self.lora = lora
          self.dev_addr = dev_addr
          self.nwk_swkey = nwk_swkey
          self.app_swkey = app_swkey
          self.mac = binascii.hexlify(lora.mac())
          self.join()
