    Connect and send data via WiFi from WiPy to LoPy
    wipywifylopy
    9 Posts 3 Posters 4.7k Views 3 Watching
      amartinez Pybytes Beta
      Regarding the problems we found to do the same by BLE (https://forum.pycom.io/topic/1282/send-data-from-wipy-to-lopy-with-ble/6), I' m asking if it is possible to send data via WiFi from WiPy to LoPy.
      Reading the documentation, it seems easy to connect, and then create a socket, but I prefer to ask you if it is possible before wasting my time...
      Thank you.
        livius @amartinez
        @amartinez
        Yes, it is possible
        But i tested this with 2xWipy2 without lopy
        But it should work same.
          amartinez Pybytes Beta @livius
          @livius thank you. Could you share any code to step on? Or any recommendations about the necessary code?
          What WLAN mode have I to choose? And what about the network security?
          I guess the connection is done similar than the example:
          import network
          # setup as a station
          wlan = network.WLAN(mode=network.WLAN.STA)
          wlan.connect('your-ssid', auth=(network.WLAN.WPA2, 'your-key'))
          while not wlan.isconnected():
              time.sleep_ms(50)
          print(wlan.ifconfig())
          # now use socket as usual
          And then, how do I send the data?
            livius @amartinez
            @amartinez
            you can use STA_AP
            or
            in "server node" AP
            in "client" node STA
            on server you must listen
            look here for sample
            https://docs.python.org/2/howto/sockets.html
            or
            here
            https://pymotw.com/2/socket/tcp.html
              @livius So, the server will be the listener (LoPy) and the Client sends the data (WiPy)?
              It's a bit confusing because on BLE its the contrary...
              In order to listen, have I to set an IP adress?
                robert-hh @amartinez
                @amartinez The access point has to set an IP address. By default this is 192.168.4.1. The AP will also run an DHCP server, which distributes IP-addresses to the client. The Client has to connect to the AP.
                It might be confusing that there are two layers of connection needed:
                • One at the link level - Access point to Station (this is like plugging in a cable)
                • One at the socket level - Client to server
                  amartinez Pybytes Beta @robert-hh
                  @robert-hh thank you Robert. The connection is set correctly, now let's try to send data.
                  Connection code:
                  WiPy (Client - STA mode, transmitter):
                  # WiPy sends data -> Client -> WLAN mode = STA
                  import network
                  wlan.connect('lopy-wlan', auth=(network.WLAN.WPA2, 'www.pycom.io'))
                      time.sleep_ms(50)
                  LoPy (Server - AP mode, listener):
                  import network
                  from network import WLAN
                  wlan = network.WLAN(mode=network.WLAN.AP)
                  wlan.init(mode=WLAN.AP, ssid='lopy-wlan', auth=(WLAN.WPA2,'www.lopy.io'), channel=7, antenna=WLAN.INT_ANT)
                  #wlan.connect('your-ssid', auth=(network.WLAN.WPA2, 'your-key'))
                      time.sleep_ms(50)
                    amartinez Pybytes Beta @amartinez
                    Update: It's not connecting really, I thought that it was printing the ifcongif but it's not. This is what it prints:
                      livius @amartinez
                      @amartinez
                      for server node it is not good to have
                          time.sleep_ms(50)
                      You do not connect wifi here only you start Access Point (AP) - look if it start on network list scan on client node side or your PC
