    Pytrack and Pysense firmware release 0.0.2
    firmwarepytrackpysense
    27 Posts 9 Posters 12.4k Views 9 Watching
      daniel
      We have released a new firmware for Pytrack and Pysense. The version is 0.0.2. These are the release notes:
      • Add possibility to wakeup via the Pysense/Pytrack pushbutton.
      • Correct the timing of the deep sleep cycles.
      • Correct the generic read/write modify function to control the PIC microcontroller.
      The instructions to apply the new firmware can be found in: ~~https://docs.pycom.io/pycom_esp32/pycom_esp32/toolsandfeatures.html#updating-pysense-and-pytrack-firmware~~
      New link: https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.html
      We will publish the libraries to use the GPS and the sensors on the board tomorrow.
      Cheers,
      Daniel
      L 2 Replies Last reply Reply Quote 1
        livius @daniel
        @daniel said in Pytrack and Pysense firmware release 0.0.2:
        How to upgrade under Windows?
          joe2612
          Some additional tips to help MAC users:
          1. After downloading the Pytrack/Pysense DFU, rename it to firmware_file.dfu
          2. Move the DFU file to Library folder
          3. Hold the push button and connect the Pytrack/sense ( no LoPY etc needed) over USB
          4. release the button and paste the command : dfu-util -D firmware_file.dfu
          5. Should be good to go!
            jmarcelino @livius
            @livius
            dfu-util is also available for windows http://dfu-util.sourceforge.net/releases/
            dfu-util-0.9-win64.zip
            Should be really similar to use (from command line)
            C L 2 Replies Last reply Reply Quote 0
              Camot @jmarcelino
              @jmarcelino said in Pytrack and Pysense firmware release 0.0.2:
              @livius
              The pysense is recognised by my Windows 10 as Serial USB device.
              alt text
              However, when I plug it in with the button pressed it says unknown device, no driver available.
              alt text
              Hence the update fails
              PS C:\Users\.....\Pycom\dfu-util-0.9-win64> .\dfu-util.exe -D .\pysense_0.0.2.dfu
              dfu-util 0.9
              Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
              Copyright 2010-2016 Tormod Volden and Stefan Schmidt
              This program is Free Software and has ABSOLUTELY NO WARRANTY
              Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
              Match vendor ID from file: 04d8
              Match product ID from file: f011
              Cannot open DFU device 04d8:f011
              No DFU capable USB device available
                livius @jmarcelino
                I have tried it before i asked ;-)
                But it say unknown vendor for me
                I have tried also -s
                dfu-util.exe -s COM4 -D pysense_0.0.2.dfu
                But have not tried much. In the evening i will try more
                  jmarcelino @livius
                  @livius
                  Ha sorry I see Windows needs a DFU driver! No problem, libUSBk to the rescue.
                  Try installing the driver package I generated:
                  [now old, see above]
                  or install libusbK and make your own using the inf-wizard :-)
                  Once that's done dfu-util -D pysense_0.0.2.dfu will work (remember you only have about 7 seconds to run it after releasing the button, so install the driver first)
                  DFU-UTIL has to be >= version 0.8
                  Tested with PyTrack not sure if the PySense uses the same ID, will try it up later.
                    daniel
                    @jmarcelino thanks for the Windows instructions and the driver package!
                      jmarcelino
                      PySense and PyTrack DFU use different USB IDs so I generated two driver packages for Windows using libusbK (I don't know how to make a single one...)
                      PySense: http://metavurt.net/software/drivers/PySense_DFU.zip
                      PyTrack: http://metavurt.net/software/drivers/PyTrack_DFU.zip
                      After installing the driver you need download dfu-util for Windows from http://dfu-util.sourceforge.net/releases/dfu-util-0.8-binaries/win32-mingw32/ , I recommend the static compiled binary to avoid any library issues, you only need one executable: dfu-util-static.exe
                      Place the executable and the dfu firmware from Pycom together and get ready to run:
                      dfu-util-static.exe -D pysense_0.0.2.dfu or
                      dfu-util-static.exe -D pytrack_0.0.2.dfu depending on your firmware and board
                      Then connect the board with the button pressed down, release the button after one second and run the command above - remember you only have 7 seconds to do so!
                      The process will look like this
                      J 1 Reply Last reply Reply Quote 5
                        jobbyworld @joe2612
                        @joe2612
                        on macbook pro :
                        I advice to specify device since another device is in dfu mode
                        dfu-util -l
                        dfu-util 0.7
                        Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
                        Copyright 2010-2012 Tormod Volden and Stefan Schmidt
                        Please report bugs to dfu-util@lists.gnumonks.org
                        Found Runtime: [05ac:8289] devnum=0, cfg=1, intf=3, alt=0, name="UNDEFINED"
                        Found Runtime: [04d8:f011] devnum=0, cfg=1, intf=0, alt=0, name="UNDEFINED"
                        so i advice to specify device :
                        dfu-util --device 04d8:f011 -D pysense_0.0.2.dfu
                        dfu-util 0.7
                        Filter on vendor = 0x04d8 product = 0xf011
                        Opening DFU capable USB device... ID 04d8:f011
                        Run-time device DFU version 0100
                        Claiming USB DFU Runtime Interface...
                        Determining device status: state = dfuIDLE, status = 0
                        WARNING: Runtime device already in DFU state ?!?
                        Claiming USB DFU Interface...
                        Setting Alternate Setting #0 ...
                        dfuIDLE, continuing
                        DFU mode device DFU version 0100
                        Device returned transfer size 64
                        Dfu suffix version 100
                        bytes_per_hash=327
                        Copying data from PC to DFU device
                        Starting download: [##################################################] finished!
                        state(2) = dfuIDLE, status(0) = No error condition is present
                        Done!
                          jmarcelino @jobbyworld
                          @jobbyworld
                          If you update to dfu-util version 0.8 or later it should pick up the correct ids from the file to filter on
                            johncaipa @jmarcelino
                            @jmarcelino thanks for the instructions!
                            @daniel where can we find examples and libraries?
                            regards
                              livius @daniel
                              @daniel
                              for me pysense + wipy2 hangs after few seconds
                              upgrade was ok
                              dfu-util 0.8
                              Copyright 2010-2014 Tormod Volden and Stefan Schmidt
                              ID 04d8:f011
                              dfuIDLE, continuing
                              Download        [=========================] 100%        16384 bytes
                              Download done.
                              Done!
                              wipy2 after fresh
                              os.mkfs('/flash')
                              with current firmware 1.7.2.b1 (official build)
                              i put 6 times os.uname() but only first 2 i get response and then it hang totally
                              all interfaces go down - wifi and uart
                              no info on COM/response on any command and no output
                              rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                              ets Jun  8 2016 00:22:57
                              rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                              configsip: 0, SPIWP:0x00
                              mode:QIO, clock div:2
                              load:0x3fff9010,len:12
                              ho 0 tail 12 room 4
                              load:0x3fff9020,len:388
                              load:0x40078000,len:11412
                              load:0x4009fc00,len:848
                              entry 0x4009fd9c
                              MicroPython v1.8.6-650-g9bacbbd4 on 2017-06-09; WiPy with ESP32
                              >>> os.uname()
                              (sysname='WiPy', nodename='WiPy', release='1.7.2.b1', version='v1.8.6-650-g9bacbbd4 on 2017-06-09', machine='WiPy with ESP32')
                              >>> os.uname()
                              i moved this wipy to expansion board and it work without any problem
                                daniel
                                @livius after it hangs, does it revive by resetting the WiPy 2, or do you have to power cycle the pysense?
                                  livius @daniel
                                  @daniel
                                  it revive by pressing reset button on Wipy2
                                  and back hang
                                  UPDATE
                                  pytrack is ok only pysense is affected
                                  J 2 Replies Last reply Reply Quote 0
                                    jmarcelino @livius
                                    @livius
                                    No problem here with the Pysense (also upgraded using Windows) and a LoPy (sorry I don't have a WiPy to test)
                                    Not sure how many checks the DFU stuff uses (would think it was reliable since it's a USB.org standard) but maybe try flashing it again?
                                      jmarcelino @livius
                                      @livius
                                      Does the Pysense after update appear as a USB serial device using the usbser driver?
                                        livius @jmarcelino
                                        I have tried before 5 times before written here
                                        also with different cable on different USB port - no difference
                                        and with really short cable (used for near everythin programing)
                                        e.g. white cable below
                                        0_1497120825859_upload-0244a2c0-5595-4f1e-b223-ccfb034a6530
                                        yes
                                        0_1497120892968_upload-a5383b83-7006-438e-b27a-1284065bc70b
                                          jmarcelino @livius
                                          @livius
                                          Sorry should have figured you'd have done that already :-)
                                          Not sure what it can be, but if pressing reset works I guess it's the WiPy crashing and not the Pysense shutting it off. Sounds like that was the question Daniel had.
                                            livius @jmarcelino
                                            for us we can assume this always ;-)
                                            • 1
                                            • 2
                                            • 1 / 2
