    ESP32 Revision
    esp32
    8 Posts 3 Posters 4.3k Views 3 Watching
    • E Offline
      Eric24
      Is there a way to determine the revision of the ESP32 in a WiPy or LoPy? I ask because there are certain issues that are mentioned on the ESP32 forums that reference a particular revision number.
      L J 2 Replies Last reply Reply Quote 1
        livius @Eric24
        @Eric24
        I do not know - but maybe helpfull is that all dev kits are 0 and OEM are 1.
        If i'm wrong someone fix me.
          jmarcelino
          All L01 OEM modules use revision 1 and as far as I know the dev kits for now still use revision 0. Revision 1 is only a few weeks old.
          There is a tool to check that through the efuses (by building a custom firmware), look in the esp32.com forums I don't have a link right now.
          • E Offline
            Eric24 @jmarcelino
            @jmarcelino OK, that's about what I expected (based on ESP32 silicon release dates). Can I assume that all Rev0 bugs that have firmware-related workarounds have already been included in the latest firmware (for WiPy and LoPy)? Is there a list of silicon bugs that have not been "fixed"?
            E J 2 Replies Last reply Reply Quote 0
            • E Offline
              Eric24 @Eric24
              PS - Link to ESP32 errata document:
              https://espressif.com/sites/default/files/documentation/eco_and_workarounds_for_bugs_in_esp32_en.pdf
                jmarcelino @Eric24
                @Eric24
                Turns out that from 3 days ago you don't need to custom flash the chip to get it's revision, just put it programming mode (GND-P2, like when updating the firmware), get the latest esptool from https://github.com/espressif/esptool/releases/tag/v2.0 and run
                ./esptool.py --port YOUR_PORT read_mac
                You should get something like this (from my LoPy):
                esptool.py v2.0
                Connecting........_____
                Detecting chip type... ESP32
                Chip is ESP32D0WDQ6 (revision 0)
                Uploading stub...
                Running stub...
                Stub running...
                MAC: 24:0a:c4xxxxxx
                Hard resetting...
                  jmarcelino @Eric24
                  @Eric24
                  The workarounds listed have been implemented in the ESP-IDF low level RTOS, which MicroPython uses.
                  Where it says "There is no workaround for this issue." well it hasn't :)
                  • E Offline
                    Eric24 @jmarcelino
                    @jmarcelino Thanks! Good to know (and that only leaves one--brown-out reset, which isn't all that important).
