    Firmware update fail with strange message if pyserial not installled (Ubuntu 16.04.2 LTS)
    lopy
    2 Posts 2 Posters 697 Views 2 Watching
    • O Offline
      olivierd
      Hi Guys,
      I have been trying to update the firmware on my LoPy, I was stuck for some time with a stupid issue.
      I want to share that with you.
      If you get a message such as
      "Something failed trying to connect to the device."
      check that pyserial module is installed (sudo pip install pyserial)
      It would be good to add a test to check if python module are installed in the update script.
      I usually use venv to develop that's why I forget to install it.
      Cheers,
      Olivier.
      P 1 Reply Last reply Reply Quote 1
        Pwntus @olivierd
        @olivierd Wow, this tip saved a lot of time. The problem still persists in the updater tool as of today.
