    Raspberry with Maxbotics
    pythonraspberry pimaxbotics
    2 Posts 2 Posters 1.1k Views 2 Watching
      Jen
      I have tried Raspberry Pi with Ultrasonic HCSR 04 Sensor. I have written a program for that. I got a proper result, but I am facing some reliability issue with that. So I thought I will use other sensors.
      Statement 2: I bought Maxbotics sensor MB 1040. I have written program in python, I got readings but that is not proper reading, I have not achieved accuracy. Kindly assist me solve this issue. Here I have attached program
      import RPi.GPIO as GPIO
      GPIO.setmode(GPIO.BCM)
      GPIO_TRIGECHO = 15
      print "Ultrasonic Measurement"
      GPIO.setup(GPIO_TRIGECHO,GPIO.OUT)
      GPIO.output(GPIO_TRIGECHO, False)
      def measure()
      GPIO.output(GPIO_TRIGECHO, True)
      time.sleep(0.00001)
      start = time.time()
      GPIO.setup(GPIO_TRIGECHO, GPIO.IN)
      while GPIO.input(GPIO_TRIGECHO)==0:
          start = time.time()
      while GPIO.input(GPIO_TRIGECHO)==1:
          stop = time.time()
      GPIO.setup(GPIO_TRIGECHO, GPIO.OUT)
      elapsed = stop-start
      distance = (elapsed * 34300)/2.0
      time.sleep(0.1)
      return distance
      try:
      distance = measure()
      print " Distance : %.1f cm" % distance
      except KeyboardInterrupt:
      print("Stop")
      GPIO.cleanup()
      • B Offline
        bucknall
        Hi @Jen,
        I think you might be in the wrong place! These forums are for the Pycom (https://pycom.io) products such as the WiPy, LoPy, etc.
        It seems as though you are using the Raspberry Pi which uses a different version of Python from that found on our devices! I'll point you towards https://www.raspberrypi.org/forums/ to find some more support for your issue!
        Thanks!
        Alex
        Developer Evangelist - Pycom
