    Problem with Sigfox Payload
    pytracksipysigfox
    21 Posts 3 Posters 7.7k Views 3 Watching
      Jiemde Pybytes Beta
      Hi All,
      Using Pytrack with SiPy for sending GPS coordinates to Sigfox backend.
      For example a payload sended by SiPy: b'\xd5\x17M\x00r\xb5\x08\x00' appear in the Sigfox backend as "d5174d0072b50800" !
      When I try to decode this payload by "int1::4 int2::4" in the payload display, I never obtain the Latitude and Longitude expected
      Is someone has the solution ? Thanks for help.
      Jiemde
      • B Offline
        bucknall
        Hi @Jiemde,
        Could you please post the code you are using to send your message?
        Thanks,
        Alex
        Developer Evangelist - Pycom
          Jiemde Pybytes Beta
          Hi Alex,
          Here is the code:
          def sendtosigfox():
          datatosend = struct.pack('ii', int(coords[0]*100000),  int(coords[1]*100000))
          print('sigfox send: {}\n'.format(datatosend))
          sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
          s.setblocking(True)
          s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
          s.send(datatosend)
          s.setblocking(False)
          s.close()
          Jiemde
            livius @Jiemde
            @Jiemde
            First question is - do you have good coordinates retrived by pytrack without sending it to sigfox?
            I ask because if you used official library then current library do not calculate CRC and do not check for fix in messages.
            And it use only GNGLL glonass message ignoring all other messages also GPS messages.
            B J 2 Replies Last reply Reply Quote 0
            • B Offline
              bucknall @livius
              @Jiemde
              That looks to be fine - What does the Sigfox Backend give you, instead of the data you're expecting? Also as @livius has suggested, what GPS are you using?
              @livius We'll be adding the CRC check and utilization of other GPS messages shortly. Thanks for your patience!
                Jiemde Pybytes Beta @livius
                @livius
                Yes the coordinates are right !
                When you take the 4 first bytes of the payload seeing in Sigfox for example " d5174d00" and you enter this part of payload in an "Lat=struct.unpack('i', b'\0xd5\0x17\0x4d\0x00') you will retreive the good Latitude.
                I think that teh code is sending the good coordinates, but I don't find how to configure the payload display in "device type" in the Sigfox backend !
                Regards
                jiemde
                  livius @Jiemde
                  @Jiemde
                  now it is much cliear where you have the problem
                  i do not know sigfox much but this format is valid?
                  int1::4 int2::4
                  i suppose you need
                  int1:uint::4 int2:uint::4
                    Jiemde Pybytes Beta @bucknall
                    @bucknall
                    The Sigfox backend display "d5174d0072b50800"
                    The decoding payload "int1::4 int2::4", display 2 integer but not the good one!
                    0_1499083800253_Capture d'écran 2017-07-03 14.06.17.png image url)
                      livius @Jiemde
                      @Jiemde
                      sorry mistake
                      int1:uint::32 int2:uint::32
                        @livius
                        Yes of course! :))
                          @livius
                          Had already tested this but not the good result.
                          jiemde
                            livius @Jiemde
                            @Jiemde
                            what are results - maybe this hint something
                              @livius
                              Here is the printscreen
                                livius @Jiemde
                                @Jiemde
                                sadly i do not have sipy to test self but
                                looking at your values i see that you have variation on most significant bits
                                try then this:
                                int1:uint::32:little-endian int2:uint::32:little-endian
                                if this does not help then post output from corrds recived by pytrack + output packed
                                and what you got for this frames on sigfox
                                  @livius
                                  No change in the displaying data.
                                  As I don't have my SiPy/Pytrack with me at my office, I will reply this evening to your other question.
                                  best regards
                                  jiemde
                                    @livius
                                    You will find the output you ask:
                                    def sendtosigfox():
                                    size1=struct.calcsize('i')
                                    size2=struct.calcsize('ii')
                                    print('calcsize: ', size1, size2)
                                    s.setblocking(True)
                                    s.send(datatosend)
                                    s.close()
                                    acc = LIS2HH12(py)
                                    roll = acc.roll()
                                    print('X= ', roll)
                                    pitch = acc.pitch()
                                    print('Y= ', pitch)
                                    yaw = acc.yaw()
                                    print('Z= ', yaw)
                                    gps = L76GNSS(py)
                                    coords = gps.coordinates()
                                    print(coords)
                                    sendtosigfox()
                                    time.sleep(600)
                                    The output in Atom/Pymakr:
                                    The output in Sigfox backend
                                    Regards
                                    Jiemde
                                    L 2 Replies Last reply Reply Quote 0
                                      livius @Jiemde
                                      @Jiemde
                                      can you add before struct.pack
                                      print(coords)
                                      or
                                      print(str(coords)) #if above not work cast first to string
                                        livius @Jiemde
                                        @Jiemde
                                        is this really your position?
                                        b'\xc8\x17M\x00k\xb5\x08\x00'
                                        (5052360, 570731)
                                        will be really helpfull to see
                                        print(coords)
                                        as mentioned below
                                          @livius
                                          Yes it 's my position !
                                          The coords are displayed just before the "sigfox send: " on the output in Atom/pymakr picture.
                                          (50.5236, 5.707314)
                                          Jiemde
                                            livius @Jiemde
                                            @Jiemde
                                            Ahh i see :) I have missed it.
                                            and i see problem (previously i have thinked in opposite direction)
                                            try do this (one of this should do the trick)
                                            datatosend = struct.pack('>II', int(coords[0]*100000),  int(coords[1]*100000))
                                            or not and on sigfox backend (i do not know why little not do the job and suppose that only above line will work for you)
                                            int1:uint::32:big-endian int2:uint::32:big-endian
                                            • 1
                                            • 2
                                            • 2 / 2
