    Cannot Sync any code to the Sipy
    syncsyncing failed
    2 Posts 1 Posters 751 Views 1 Watching
      chrisi
      After increasing the sample rate of which the sipy records the accelerometer from the pytrack I can nolonger sync any code to the sipy. This is the error message I get:
      I have tired using the other sipy device I have and that did sync the first time and after running the code the same problem occurred.
      any help would be greatly appreciated.
        chrisi
        I found that by doing a Factory reset the problem is fixed
        Factory reset the filesystem
        If you device’s filesystem gets corrupted (very unlikely, but possible), you can format it very easily by doing:
        import os
        os.mkfs('/flash')
