    Sending packets via WiFi from Gateway to PC
    lopywifi send data
    6 Posts 4 Posters 2.5k Views 4 Watching
    • F Offline
      finnzc
      Hello everyone,
      I'm quite new with LoPy and had very limited knowledge in network. I followed a simple tutorial on setting up a server on PC and a client on Pycom but it didn't connect with PC.
      PC (server):
      import socket               # Import socket module
      s = socket.socket()         # Create a socket object
      host = name          # Get local machine name
      port = port_number                   # Reserve a port for your service.
      s.bind((host, port))        # Bind to the port
      s.listen(5)                          # Now wait for client connection.
                 c, addr = s.accept()        # Establish connection with client.
                 print 'Got connection from', addr
                 c.send('Thank you for connecting')
                  c.close()                # Close the connection
      Pycom(client):
      s.connect((host, port))
      print(s.recv(1024))
      s.close                                # Close the socket when done
      I'd like to send simple packets of data from Pycom using socket.send() and receive it in my laptop using socket.recv(). However, the problem I'm encountering is that as I run the code in Pycom, I'm getting OSError: -1 in s.connect(). Help is very appreciated :)
        livius @finnzc
        @finnzc
        did you connected Lopy by Wifi to your router?
        https://docs.pycom.io/chapter/tutorials/all/wlan.html
        • F Offline
          finnzc
          No, I haven't connected LoPy to the router. I was thinking of sending WiFi packets directly to the laptop. Could you explain why is connecting to the router necessary?
          Thanks @livius
          ahaw021A 1 Reply Last reply Reply Quote 0
          • B Offline
            bnjroos
            @finnzc if you want to send the wifi paquet to your laptop you still need to connect the LoPy to your laptop with maybe your laptop setup as AP.
            • ahaw021A Offline
              ahaw021 @finnzc
              hi @finnzc
              I suggest a quick google of how Wi-Fi networks work may be useful
              To answer you question - in order for devices to communicate in WiFi they all need to be joined to the same network. This can be done one of two ways
              A) Using a router - this is the most common way for example your LoPy, Laptop etc are all connected to your "home wifi" which is a router advertising something called an SSID. The router keeps tracks of all devices on the network and is able to pass packets between them
              B) Using your laptop as a router. You can configure your latpop to not join a network instead act as the router itself. I don't recommend this path as it does require a good understanding of wifi networking principles
              Andrei
              F 1 Reply Last reply Reply Quote 0
              • F Offline
                finnzc @ahaw021
                @ahaw021
                @bnjroos
                Thanks for the information, I really appreciate it. I'd like to give a go for option A as it seems more straightforward. :)
