Power up wipy from raspberry pi 3
Maybe is a silly question, but is it possible to connect directly a gpio pin of a raspberry to the wify2 or the pytrack to power it up? I don't want to burn both lol
as i can see from the pinout, raspberry has 2 5v pins and 2 3.3v. so i shoud use 5v + gnd? or 3.3 + gnd?
@bucknall ok, thank you! I had not considered that the pytrack hasn't extra female pins, so i think i'll start with a standard usb connection, because i don't want to have to solder, at least for now.
I'll have a look at the lopy-raspberry code :D
Hi @ozeta,
I would use the 5V pin + GND but make sure you connect them to the voltage regulator pin (Vin + GND) on then WiPy 2.0 as you can risk damaging the device otherwise.
If you're looking at communicating between the two devices, you might find this useful!
