    LoRaWAN MAC Battery Level reporting
    lopy lorawan
    4 Posts 3 Posters 2.1k Views 3 Watching
    • bmarkusB Offline
      bmarkus
      There is a lora.set_battery_level(level) method introduced in latest firmware:
      0_1501737154368_upload-d0def910-09e4-4876-b871-aaee637a699b
      Unfortunately current implementation is not in line with LoraWAN Specification v1.0.2
      0_1501737300888_upload-2c6e55f3-b554-4458-9196-f5b743643866
      Method is passing values between 0 and 100 to the LoRaWAN server directly which means on server side 39% for level=100, 20% for level=50, there are no way to report battery level 40-100%.
      Default value is 0 which indicates device is running on external source, level=0 doesn't mean 0%. Proper default value would be 255 which by the way can't be reported via this method.
      I advice to allow level=0...255 and use level=255 as default, adding the quoted text from the LoRaWAN specification to the documentation.
      • B Offline
        bucknall
        Hi @bmarkus,
        Thanks for the bug report! Would you mind creating an issue on our GitHub repository for this?
        https://github.com/pycom/pycom-micropython-sigfox/issues
        Thanks!
        Developer Evangelist - Pycom
        • bmarkusB Offline
          bmarkus
          Sure, I will open an issue at GitHub.
            daniel
            @bmarkus thanks, fixing it now.
