    [SOLVED] Error sending the same information several times
    lopydataerror sendingloop
    4 Posts 2 Posters 1.4k Views 2 Watching
    • B Offline
      bihut
      Hi guys!.
      I have a problem, that just started (I think) with the new upgrade (1.7.9.b1), because yesterday was working very good and this morning after upgrade the firmware stop working properly..
      Basically, I have the following source code (is a basic source code to send information through lora):
      dev_addr = struct.unpack(">l", binascii.unhexlify('XXXXXblabla'.replace(' ','')))[0]
      nwk_swkey = binascii.unhexlify('YYYYYYYblabla'.replace(' ',''))
      app_swkey = binascii.unhexlify('ZZZZZblabla'.replace(' ',''))
      while not lora.has_joined():
          pass
      soc = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
      soc.setsockopt(socket.SOL_LORA, socket.SO_DR, 5)
      soc.setblocking(False)
      def sender():
          soc.send('ping')
          print("send ping")
          time.sleep(3)
      Well, if I complete the code running the sender() function:
      sender()
      I get always the same result in my IoT platform (LoRa Server): baa527f5. That is, I always sent the 'ping' string and get always the same data (baa527f5), so that is fine.
      But If I put the sender() function in a loop, I get each time different information in my IoT backend: 25d1c825, 2352feeb, c073cbce
          sender()
      So, how is possible sending the same information ('ping' in this case), I get different information just doing inside a loop?.
      Any thoughts?.
      Thanks in advance and best regards.
      • B Offline
        bihut
        No one?No ideas?
          jmarcelino
          Update to 1.7.1.b3, there was a problem with LoRa on the earlier build.
          • B Offline
            bihut @jmarcelino
            @jmarcelino Yep, you're right. Know it works perfectly.
            I did not now that a new version was released! =).
            Thank you very much!
